MTGreen
Platinum Member
- Joined
 - Oct 12, 2022
- Messages
 - 999
- Location
 - Montana, USA
- Tractor
 - Deere 5220, Ford 1720, Deere Progator 2030
Posting pics would help along with pics of the exploded parts diagram from your manual.
Getting a seal out from around a long shaft buried inside a bell housing without pulling the shaft out of the case/bellhousing is going to be difficult, and the o ring or other seal in between the two shafts is going to be impossible.
Does the bell housing separate from the trans case? Because that's where I would look next -if you can pull the bell housing/front case off of the shaft you will be able to get the numbers off the seal without destroying it and replace it easily. In addition, you may be able to pull your hollow shaft off of your inner shaft and address that seal as well
