Menagerie-Manor
- Joined
- May 24, 2021
- Messages
- 427
- Location
- Brookings Oregon
- Tractor
- Yanmar YM2310D John Deere LX172 Woodland Mills HM126
Finally getting my Mill setup, been off and on rain for the last 6 weeks.
Of course. Most of my pine logs are in the 22-24" range, a close fit. Then a friend needed a big ash taken out of his pasture, had to use the first 10' as firewood, just way too big for the mill.Are you saying that sawmills are like tractors and boats, you always want something a little bigger?
I thought a laser might be handy, but since I started using my mill I hadn't even thought about it until it was mentioned above.
Of course. Most of my pine logs are in the 22-24" range, a close fit. Then a friend needed a big ash taken out of his pasture, had to use the first 10' as firewood, just way too big for the mill. And if you look back at post #30 you can see some of my logging equipment. I use the BCS walk behind because it is too steep to pull a 2000 lb log with a BX2230, so maybe a bigger tractor may be in the future.Are you saying that sawmills are like tractors and boats, you always want something a little bigger?
My Woodlander is the portable one, may have a shed sometime in the future, probably distant future- Just like a bigger tractor.Yeah I figured until I get a roof of some sort the laser would be hit and miss . I also have trees all around me so that should help .
Brandi this is the 3rd time I've used them, almost as clear as glass. It's a polycarbonate panel with a very good warranty. My oldest panels are 5-6 years old and the same appearance as the new.Rustyiron,
I like the idea of the clear roof panels. How do you like them? If you did it over, would you still put them in? Do they have a warranty for so many years?
hugs, Brandi
Reading back through this thread, I saw your comment about wavy cuts in cedar. While cutting some maple today with a friend, I mentioned I have some cedar to cut up for a deer blind. He said cedar is a hard item to cut and I will dull blades faster. Don't know if true or not, will find out latter.I sawed out a small cedar today. I needed (two) 4x4 posts and also got some 2x4s. More practice is needed, as I am getting too many waves in the boards. I believe that's speed related, I need to work on a more steady movement through the log.
I also am considering a chainsaw mounted debarker, the wood seems clean and was cut with snow on the ground yet my blade is already getting dull.
Right now I have a pine log on the deck which I cut last summer. I wanted to saw more tonight but it was end of the day after work, and that's when I start making stupid mistakes.
Yes I did figure that out, but thank you for mentioning it. Another thing I realized is that I sometimes am trying to saw too fast.But on the wavy cuts, I notice while cutting 20" red pine and pushing a blade past its sharpness, I had some wavy areas, especially at the knots. Changing to a new blade and back to straight cuts. Maybe you have since found that out.
