Schrader fitting, for setting tubeless tires (small & motorcycle etc)
   / Schrader fitting, for setting tubeless tires (small & motorcycle etc)
I did that once, but didn't use the fuse method. I was quite satisfied how well it worked. I used just a small amount of starting fluid and a BBQ lighter. Had to try several times. The next time I tried it, never could get it to work.
That method with the fuse looks like it works a lot better but maybe wouldn't want to do it out in the forest! Thanks for posting.
Heres another thats more like my experience.
   / Schrader fitting, for setting tubeless tires (small & motorcycle etc) #22
times. The last time I never could get it to work.
Good video, SODO. I have tried this method, too, and never got it right. I need more practice, I guess.
Note the guy in the video had to try a number of times to get it right, too.
I agree with him about the straps....I have done it that way, too, but it concerns me about the additional
tension it puts on the strap. I do NOT try to release the strap until I have let air back out of the tire.
With the fire method, having the schrader valve out of the stem, and lots of air coming in is a very important
part of the procedure.
   / Schrader fitting, for setting tubeless tires (small & motorcycle etc) #23
I have done this numerous times with considerably more success I might add. I don't use starting fluid though it will work. I use propane because it's what I have. The bonus is that propane sinks in air so it's naturally going to go into the tire. If I have a failure where the bead does not seat I blow air into the tire to provide fresh oxygen as there is none left in the tire after it's all burnt up from the failed attempt. Other than that he does everything the way I generally do it.
I think it would be wise to point the valve stem away, in case it blows out of the hole. Or it should be clipped into an air hose.
UNUSED DIGGIT 6'5"-10 DRAWER, 2 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
(INOP) ARTIC CAT 400 4-WHEELER (A54756)
(INOP) ARTIC CAT...
2019 Chevrolet Express 2500 Cargo Van (A53422)
2019 Chevrolet...
RHINO 160 - 5' ROTARY MOWER, 3PT (A54756)
RHINO 160 - 5'...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2017 Ford F-150...
