Seemed Like Such A Simple Project
   / Seemed Like Such A Simple Project #101
Yep, Mike, I agree if I'm mixing it in a wheelbarrow, but then it always seemed that the water would not soak down into it well until you stirred it, including scraping the bottom to get the dry stuff up into the water, so if you put the water in first, seems that the dry stuff is heavy enough to fall on to the bottom and get wet in the process. But like I said, I don't know; just wondering. And of course, it may make no difference either way.
   / Seemed Like Such A Simple Project #102
I've also heard of people just dumping a bag of concrete mix in around a fence post and not adding any water, assuming that it will absorb moisture from the ground.
   / Seemed Like Such A Simple Project #103
In a wheel barrow, tub, bucket or whatever I always did it dry mix first then added water to suit me.
Tony -
I have seen that "test cap" thingy you mention, but I didn't see one in the store when I was shopping. It would definitely be less vulnerable than having it stick up the way I have it now, but if the top of the sleeve were even with ground level, I would still be concerned about junk falling in while I was putting the pole in or out.
No matter how I do it, I'll always find something to worry about. /w3tcompact/icons/grin.gif
Bird -
<font color=blue>I wonder whether either way actually works better</font color=blue>
I can tell you that when I added the water, it took a loooooong time for it to fully sink in. Maybe an hour or so. I also wonder if these instructions are unique to the fast-setting stuff.
   / Seemed Like Such A Simple Project #105
I wonder if adding the mix first and then the water helps avoid those ugly grey splashes on the posts?
The first time I mixed in the hole was while helping my neighbor install a fence in '78 or so. He was a contractor and I was just providing labor. We added the mix first, then water and then I got to use a piece of rebar to mix it in the hole. I wish I would have seen Harv's directions...
-david
   / Seemed Like Such A Simple Project #106
There are applications called soil cement, and cement is introduced to soil, then mixed , with water added. Works ( worked ) well. Not sure if anyone still uses it though.
Soundguy
   / Seemed Like Such A Simple Project #107
<font color=blue>So for the first time that I can remember, I actually followed the instructions! </font color=blue>
Now I've totally lost all respect for you /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
   / Seemed Like Such A Simple Project #108
Great job Harv! /w3tcompact/icons/wink.gif
How come you didn't take a close up picture of your initials in the concrete?? /w3tcompact/icons/crazy.gif
<font color=blue>How come you didn't take a close up picture of your initials</font color=blue>
Dang! I knew I forgot something! Maybe I'd better start over... /w3tcompact/icons/grin.gif
   / Seemed Like Such A Simple Project #110
And all these years like you I've been busting my butt mixing concrete in a wheelbarrow- but than again maybe what I really need is one of them 3-point PTO mixers!/w3tcompact/icons/wink.gif
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2022 Ford F-150...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
UNUSED MOWERKING SKID STEER BOX BROOM (A50460)
UNUSED MOWERKING...
Mccormick Hammer Mill (A48837)
Mccormick Hammer...
2020 KUBOTA SVL95-2S SKID STEER (A50458)
2020 KUBOTA...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A48081)
2009 Hino 268...
