Septic system leaching bed failure
   / Septic system leaching bed failure #1
Botabill
Platinum Member
Ontario
Perhaps my question is being put in the wrong place but I figure some of the equipment folks on here work on septic systems so... My leaching bed is backing up (failing to drain) Is there a preferred way to identify the problem? I have a small excavator and can dig the drain tiles up anywhere easily but I'd like to minimize the intitial test holes til I'm ready to fix whatever needs fixing(Don't want to dig up the whole be if the problem is in one area.) The other question is do any of the chemicals (fast fix solutions) actually fix a clogged up leaching bed.
   / Septic system leaching bed failure #2
there is most likely no way to repair it the ground becomes saurated with grease and soap and the only way to repair it is to replace the whole thing and it will most likely have to be moved unless it is a sand mound then you just remove the sand and stone and replace same just make sure it is the leach field and not the pipe broken coming out of the tank that happens a lot
   / Septic system leaching bed failure #3
Well I hate to tell ya this, but as the other poster said there ain't no easy fix. What often happens is the septic tank gets over full with solids which then enter the leach field and clog the gravel/soil. Regular septic tank pumping evry few years is the best preventitive. Once clogged though, the leach field will need to be replaced. Pump the tank first, or else when you break the outlet pipe you'll have a raw sewage geyser, thats not pleasant. The new leach field can be close to the old one, best to ask a local engineer how/what/where to place it and how deep your soil conditions will allow the grave bed.
Its really not too bad and just amounts to some digging, drain rock (1 1/2" gravel) and some perforated 4" drain pipe (cheap) but you really should get directions from someone knowledgable and local. If no one knowledgabe is availabe, and your water table is low, say below 10', then you could just bootleg the new leach lines by digging a trench with 3'-4' below the pipe filled with gravel, be sure the new pipe has about 1/4 bubble fall, and then cover the new pipe with paper before backfilling. 80' of this should work just fine, of course its best to do it proper and get the permits and engineered design, this is just rule of thumb.
   / Septic system leaching bed failure #4
Maybe check out your local regulations for septic systems before you start anything. Some places are pretty picky about them.
Thanks gents for good advice. What does "bootleg the new leach lines" mean Syncro. Does that mean leaving the old lines in place and simply running some new leach lines in between them from the header?
Would it also be an option to simply remove the old leach lines and gravel then replacing with new if a new sight is not available?
   / Septic system leaching bed failure #7
The trouble with just removing just the pipes and gravel is that the soil around the leach field will still be full of sewage and in most cases will not let the water drain from the system in a very short time you will have the same problem again. One of the biggest problems most people make with a septic tank is what they put in it all the household cleaners on the market now days are full of chemicals which kill the bactaria in the system so keep all that out you can also a package of active yeast every couple of months will help its the same thing as RID-EX or the other other tank treatments with out all the fillers. Like the other poster said check on the local regulations the fines are rough myself as a contractor the can fine up to $5000 a day if you install or repair a system with out the proper permits the only thing you can do is fix a broken pipe with out to much trouble. I have heard that they can condemn the home untill its repaired to there likeing but not sure about that I do know that in Pa. the DEP is like Gestapo.
   / Septic system leaching bed failure #8
Have you probed the lines to make sure they have water at the ends? Are there any trees close the lines? Is the pipe from the tank to the drain field cast iron? These are some of the things we run into.
If the lines are not full of water, start out closer to the end of the line and dig down and see if there is any water. If there is no water move on towards the tank 10 feet or so and dig down again. Then replace pipe if it is stopped up. If there are any trees nearby that is probably the problem. Around here people used to use cast iron pipe. That stuff corrodes shut from the slow flow of water and has to be replaced.
   / Septic system leaching bed failure #9
When I bought my house I dug up the distribution box to my leech field and found that it wasn't level. It was sending almost all the sewage to a single leech line. It was also old and crumbling apart from too many blackberry roots attacking it.
I replaced the distribution box and used the fancy new leveller thingies and I'm pretty sure the system is working much better. I notice a much more even greening pattern on the field in the summer time.
I think the first place to check would be the distribution box. It was not too much work to dig up and replace but yes . . . it was a sh***y job.
   / Septic system leaching bed failure #10
I bought my place with a septic system that was 23 years old. I found the tank lid and opened it and found (with a piece of 1/2" conduit) it was 90% full of solids and loaded with cigerete butts. The house had been empty for 2 years. I dumped a box of Ridex in and went on to fixing other stuff. System kept working so a year later I opened the tank again prepared for the worst and no solids!!
It later started working slow and I found the tank outlet lid and this time I dumped root killer into the 3 pipes. It started working again.
I also read somewhere on the net about putting Hydrogen-Peroxide in the drain field to expedite the bacteria action. I do this every so often. They have Peroxide at the dollar store for $1.00 a quart.
If you have any trees near it they will find the drain field and stop it up. If you try root killer (Copper Sulphate) it says do not use on septic systems but if you can get to the outlet it shouldn't kill the bacteria in the tank.
I dug down to the header (distribution box) to have a look then opened a leach line. The leach line is plugged with muck. Is it typical to have a line full off muck or should they be partially hollow still. I'll didn't dig a line at the end today to see what's in there. Yes there is a beautiful tree growing right beside the leach bed and I'm sure that's one of my problems. No cast iron it is 20 years old and they used plastic header with clay tiles.
   / Septic system leaching bed failure #12
Honestly, your system sounds too far gone to save. Our local septic guys told me they try to salvage systems by pumping a strong base like lye down the pipes, and then they have a high pressure spike that they pound into the ground and shoot high pressure air bursts through to loosen the soil in the drain field. Our local regulations require a full pumpout ever other year (we are in the 'exceptional value French Creek watershed'). Here, they rarely put in-ground systems in anymore, we all have giant sand mounds, consider that approach if you replace it. Mine is 100x20x6, with 250 tons of sand in it! Best of luck.
- Patrick
   / Septic system leaching bed failure #13
Your lines should be clean, it sounds like the tank was never pumped and solids migrated into the leach bed. Time for a replacement, buckle up, It won't be cheap. I'll second the raised bed suggestion. It's the only way to go. Mine's 1000 tons of sand, 400 tons of stone, 2 1000 gallon tanks, 3 distribution boxes and 15 50' laterals. I handled all the labor and finish work, it still cost $10K+. I had the misfortune of having to replace a drain field at my last house, (brand new, bad installation by pro's....) and wanted to make sure I never had to replace this 1 in my life time.
   / Septic system leaching bed failure #14
It's probably shot and "legally" you should probably replace it. You could try shoving a garden hose with some clean water running down the line and see if you can get it down there. If it's just clogged at the entrance then you may be able to pull/suck all the crud out and get some new life in the system.
If you can unclog the lines and then get clean water running through the system then it may work for a while longer. Don't run tons of water just enough to test and see if it can still drain properly.
If the leach lines have been dry for a while then they may be salvageable. If they are completey saturated then it sounds like you need to replace it.
Disclaimer: I program computers for a living - I'm not an expert. Where's HighBeam - he's an expert?
   / Septic system leaching bed failure #15
Holy Cow! And I thought mine was huge! (It IS huge). I have two 500 gallon settling tanks in series, a zaebel filter on the line to the 1000 gallon pump tank, with the pump a foot off the floor of the tank. Also, a monster 2 HP grinder pump because my sand mound is 500 feet away and 30 feet up.
   / Septic system leaching bed failure #16
Have no idea on Canada, but I would guess you have tough codes. If you have "muck" after the tank you have problems my friend! The tank may have never been pumped or your outlet baffle may be broken or gone. I would really talk to a pro if you are unsure what your into, you may be able to do it yourself with some direction.
Illinois License # 049-804586
   / Septic system leaching bed failure #17
Like the other poster said check on the local regulations the fines are rough myself as a contractor the can fine up to $5000 a day if you install or repair a system with out the proper permits...
I agree with this completely.
I have no idea about Canada, but in Oregon, they will fine me unmercifully if I do even the slightest thing not to their specifications with my septic field. And, if they ever discover I did something without the correct permit, I might as well just turn my entire bank account over to them for the next five or ten years.
Thanks for all your input. Sounds like this could be more complicated than I thought. I'll be calling for some local professional advice.
   / Septic system leaching bed failure #19
The newer systems can have filters in tank and some have vent or vents located in leachfield to maintain a good oxygen supply to leachfield. Theses things can be added to older systems to possibly help them. Water softener discharge into septic especially if system uses salt,minerals, can be problem for field and cause baffles in older tanks, [because original baffles were precast ]and precast D-boxes to deteriate as well. Washer machines especially top load machines can cause more lint in septic tanks ,than front loader machines which use less water as well.Peple on certain medications, treatment can cause problems for septic because antibiotics, medications kill the bacteria action in septic tank. Newer systems usually call for mulitple tanks or multiple compartment tanks to seperate wastes better to keep solid matter from getting to leachfield. It is legal in NH to seperate softener discharge and drain it seperate outside of house, but can be ilegal in other states like Ma. whereit has to drain into septic. plowking
   / Septic system leaching bed failure #20
My friend just went around with the plumbing inspector when it came to the "drain" for the water softener.
Said it couldnt drain to the septic... but to just run it outside to the lawn! :eek:
my friend was like... how is that better than running it through the septic?!?! weird rules....
2013 Jeep Wrangler 4x4 SUV (A59231)
2013 Jeep Wrangler...
2021 KOMATSU WA200-8 WHEEL LOADER (A60429)
2021 KOMATSU...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
