Septic Systems - Aerobic vs. Conventional
   / Septic Systems - Aerobic vs. Conventional
If you have been approved for a conventional septic tank and field line system, that's what I would put in. As already pointed out, conventional systems are the most trouble-free and need the least maintanence.
I'm not familiar with that brand. If you must put in a mechanical plant, I would suggest a NORWECO. They've been building wastewater treatment systems, both commercial and residential, for over 30 years. I have installed a few, and they are really good systems. You will need to contact a local authorized installer.
I went to the NORWECO site and this is what they had to say about conventional/anaerobic systems:
"The slower metabolism of the anaerobic bacteria dictates that the wastewater be held several days in order to achieve even a nominal 50% reduction in organic material. That is why septic tanks are always followed by some type of effluent treatment and disposal process. The advantage of using the anaerobic process is that electromechanical equipment is not required. Anaerobic bacteria release hydrogen sulfide as well as methane gas, both of which can create hazardous conditions. Even as the anaerobic action begins in the collection lines of a sewer system, deadly hydrogen sulfide or explosive methane gas can accumulate and be life threatening."
They had this so say about aerobic septic systems:
"The metabolism of aerobes is much higher than for anaerobes. This increase means that 90% fewer organisms are needed compared to the anaerobic process, or that treatment is accomplished in 90% less time. This provides a number of advantages including a higher percentage of organic removal. The by-products of aerobic bacteria are carbon dioxide and water. "
They are basically backing up what I stated before. That anaerobic systems are nowhere near as efficient as aerobic systems. An aerobic system dissolves the waste in 90% less time than an anaerobic system. How and what kind of aerobic system one uses, that is open to debate as there are many aerobic systems, some better than others.
This takes me back to square one. All these companies are in business to sell their products, which is fine and understandable. I don't claim for a minute that if one requires an engineered system to simply install an aerator. What I am stating is that if one has been given an "OK" for a conventional system, there would be no harm in taking that conventional/anaerobic and adding aeration, creating an aerobic system, which will make the conventional system run 90% more efficiently.
An $800 aerator with a $7,000 conventional system VS. a $25,000 system is what I am facing. I don't see any harm in introducing aerobic bacteria into a conventional system and all the studies back my premise and it costs me only $800.
   / Septic Systems - Aerobic vs. Conventional #53
So, is this $800 aerator going to run on solar power or conventional wired electricity? What is it going to cost to get electrical power to the site? Once you have the aerator motor, how will you mount it into the tank? At what depth will it operate? Will it just stir up solids and keep them in suspension so that your leach field gets filled and stops up?
Aerobic systems are engineered to make sure the solids stay where they are supposed to be and clean effluent goes to the leach field or sprinkler heads. My aerobic system has a fine filtration system to remove solids and treat the effluent with a tiny bit of chlorine to stop any bacterial activity inside the collection tank.
My point is that if a conventional system could be easily improved as you describe, it would be a common thing. I think it is not an easy thing and you will end up with an expensive mess on your hands that is unmantainable and something else to worry with on a regular basis. If you have been approved for a conventional system, why don't you just put that extra $800 into a superior leach field or larger tanks and have something that will really make a difference?
I know you want the best and I applaud you for that. I just think your premise that you can have a pseudo-aerobic system by simply adding an aerator pump is false. If you can find somebody who has done as you suggest and is happy with the result, I will happily eat my words and be your greatest cheerleader. In the end, I think all of us want to give you the best advice.:thumbsup::)
   / Septic Systems - Aerobic vs. Conventional #54
Jim, good explanation. :thumbsup: Saved me a bunch of typing.
The aerator pump runs (24/7) on electricity and costs $5 a month to run. I actually run aerator pumps on my Koi pond. So I know how they work and the costs involved in running them. They are very efficient and don't take much electricity to run.
I don't have to run power to the site. The aerator pump sits inside a garage and a buried PVC air line runs to the site. The aerator does NOT get mounted to the tank. It sits indoors (garage) and the air line goes outside and is trenched to the septic tank.
The actual air diffuser sits at the bottom of the 1st chamber. Seen here:
Septic Tank Aerator, Septic Problems, Septic Repair, Septic Maintenance, Drainfield Repair, Septic Tank Diffuser
The air diffuser sits in the 1st chamber and the effluent/liquid moves to the 2nd chamber where any solids that got through will settle and if anything tries to get out the 2nd chamber drain line to the leach lines, the effluent filter will stop it. No different than in a conventional tank that is NOT aerated.
The fact is that a conventional system can and does get improved with simple aeration. I actually got off of the phone with an engineer (20 years) in the septic industry and he was VERY OPEN and honest and completely backed what I was stating. He said the reason it is not a "common thing" is that it all comes down to $$$$ and keeping people in business.
We are all grown men here, we experienced life, can you claim that everything that industries do is for the BETTERMENT of the user? Of course not. Things we buy are a lot of times made cheaply, why? Because it will make you buy it again, and again, and again, plus the cost of repairs and maintenance keeps them in business.
http://www.septicaerator.com/FAQs.html
It is not false. The engineer I spoke to, who was candid told me that the systems do work. I have contacted people who utilized the system and they said it was the best $$ they spent on their septic systems. It made a night and day difference on their conventional systems.
Once again, if the site does NOT pass for a conventional system, then this aerator is NOT a fix for them and they will require a completely engineered aerobic system. But if the site passes for a conventional system, adding aeration and creating an aerobic environment within the tank WILL help the system function 100x better due to the aerobic bacteria.
Even the companies that were recommended to me, they all utilize aeration, some even utilize the same air diffusers I am looking at.
In the end it comes down to what works better and how much $$$ does it cost.
I have 3 options:
1 - Install the conventional system that is NOT aerated and have a system that is very inefficient, produces deadly gases, and because of it's anaerobic design will eventually fail. Cost = $7,000
2 - Install the NORWECO or similar system and spend high monthly bills running the mechanical pumps and all the required power needs they use. Require costly mandatory yearly inspection contracts. Have to clean and inspect it every 3-6 months. Cost - $25,000
3 - Install the conventional system that IS aerated that will produce 90% better efficiency over the anaerobic setup. Spend $5 a month in electricity. Cost = $7,800
That is what I am faced with. Sure, the NORWECO or similar $20K+ systems are very efficient but I don't need an engineered system on my lot. So why spend another $20k + high electric bills every month on something I don't need? That leaves me will options #1 or #3. Option #3 is my best option.
I have yet to talk to someone who used that setup that hates it or has had problems because of it. If I do, then I will rethink my position but so far I yet to find anyone who had things go bad because of the aeration.
   / Septic Systems - Aerobic vs. Conventional #57
Well, it sounds to me like you have made up your mind. I am not convinced you will have a less trouble-free system by adding what consists of basically a fish tank aerator bubbling air up through the biomass. Perhaps I am wrong. The visual illustrations used to demonstrate a need for this aerator are of poorly designed or poorly maintained systems. This tactic is not unknown in marketing of many products. If people would separate their gray water and not put so much grease, soap scum, bleach, or other bacteria killing materials down their drains, they would see far less problems. That said, I just hope your system will be trouble free and you'll do a separate gray water drain. I assure you that the money spent on keeping gray drain water out of the septic will be worth every penny you spend and cost nothing to maintain over the long haul.
BTW: My aerator motor is not costly. If it adds $10 to my monthly electric bill, I would be surprised. Probably the pump that feeds my sprinklers about once daily for 10-12 minutes is going to use as much as the aerator pump. My first aerator pump lasted 7 years, so they are long-lived. I think you will find your air pump lasts no longer and uses only slightly less power.
My aerobic system was installed in 2000 at a price of $6500 and county fees. That included the first two years of service contract. My service contract now costs me $225 per year, but I could get it cheaper if I didn't use my current contractor. I don't mind paying a little more for the reliable and professional people he hires to do my service. I'm extremely pleased with my system as you can tell.
Please keep us informed. It will take awhile to prove the concept works, but I for one would like to see photos and a description of your installation. Your company is not the only company doing such conversions. If this practice proves to have long-term benefits, one day it may be a requirement.
If the aeration causes problems (which I don't see how), then I will simply turn it off and keep it as a conventional anaerobic system, which it originally was anyways. No harm no foul. I can take the aerator pump and use it on my Koi pond.
I was told by the company rep himself that to run a NORWECO system is around $25-$40 dollars a month, depending on utility rates. The aerator pump costs only $5 a month and every 5 years you replace the diaphragm assembly which costs $40 and takes 30 minutes. I do it on my Koi Pond pumps every 2-3 years.
The other system was nowhere near your $6,500 amount, it was bordering $20,000 + with installation, delivery, etc. Add the annual service contract which was around $500 a year. It was not cheap, that is for sure.
I will and I do appreciate the help and comments. I understand where you are coming from but I believe there is more than one way to skin a cat.
What were people paying for the NORWECO systems back when you installed them?
After the final treatment, is the effluent flowed by gravity into a leach field?
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
UNUSED JCT SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED JCT SKID...
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
3 PT ATTACH SPREADER W/ 12" CHAIN (A51243)
3 PT ATTACH...
