Sharp corners on FEL leading edge
   / Sharp corners on FEL leading edge #11
Oh no; when the cutting edge was replaced on the bucket I made sure it was extended one and a half inches beyond the side of the bucket. Makes for a nice edge to cut things like roots, get a edge on a stone, make a nice slice in the side of a building and so forth.:thumbsup:
Loader should not be up with no operator on the seat and hard hats can take a lot of bumps.:D
   / Sharp corners on FEL leading edge #12
Rubber baby buggy bumpers!
   / Sharp corners on FEL leading edge #13
I will tell you another outfit that is somewhat "toothy" that is the business end of my "wicked" grapple.. those lower tines are darn sharp when it comes from the factory. They are a little duller now, but still not something to mess with!:eek:
   / Sharp corners on FEL leading edge #14
"if you really care about safety, you'll" - lower all implements when not in use.
   / Sharp corners on FEL leading edge #15
That's common practice as corner wear is often faster/greater than the whole.
The point brought up concerning lowering attachments to the ground is valid, on point, and the real answer to the "problem".
   / Sharp corners on FEL leading edge #16
RalphVa
I'd be interested in seeing a pic of the edges you are concerned with. And wondering if all buckets have them, or just certain ones.
   / Sharp corners on FEL leading edge #17
JD, if you really care about safety, you'll round off the ends of the FEL leading edge. I was working around it yesterday and leaned over and poked a hole in my forehead.
Called my handyman who happens to have a heavy duty grinder. He came today and rounded off those corners. Took him less than 10 minutes.
Been thinking about doing it for quite some time. JD should have done it.
Ralph
Don't let the Government hear about your mishap. They will require safety head gear to work near your own tractor. Just poking fun, glad you are ok.
   / Sharp corners on FEL leading edge #18
RalphVa
.........X2
Here's the rounded edge of the bucket on my 1025 now. MUCH safer. I don't have to worry so much about running into it with a bare leg or hitting it with my head like I did. Took my handyman about 10 minutes and cost me $16.
Ralph
   / Sharp corners on FEL leading edge #20
That cutting edge still has paint on it. Put it in the dirt instead of flesh. Blood ruins steel!
PALLET TOTE OF CERAMIC TILES (A58374)
PALLET TOTE OF...
2008 Ford Taurus SEL Sedan (A55973)
2008 Ford Taurus...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2014 Freightliner 122SD Day Cab Truck, VIN # 3AKJGNDR0EDFL0999 (A57453)
2014 Freightliner...
Honda utv cart (A56859)
Honda utv cart...
8400 GALLON POLY TANK (A52708)
8400 GALLON POLY...
