Shear bolt question.
/ Shear bolt question. #1
birch
Can someone tell me the relative shear strength of a regular grade 2 bolt versus a grade 5 shear bolt? Which one will shear sooner? Thanks.
Birch
/ Shear bolt question. #2
Birch
I can't tell you the #'s. You can try a goole search . The # 2 will shear b-4 the # 5. the higher the grade # the harder the bolt
/ Shear bolt question. #3
Welcome and the grade 2 is the weakest then it goes to grade 5 with 3 lines on the head then to grade 8 with 6 lines on the head and are usually yellow/gold in color
Jim
/ Shear bolt question. #4
Can't tell you the difference. But I can tell you to use the shear bolt that the manufacturer sells for the machine, as long as the machine is still in the warranty period, or you'll void the warranty. Sometimes an unmarked bolt will stretch and bend, but not shear. Amazing how a 10 cent part can sometimes outlast an expensive, complicated mechanism!:eek:
/ Shear bolt question. #5
Use the right one, better to shear the bolt than break the machine.
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
46186SFL (A64557)
46186SFL (A64557)
2006 GMC T7 4X2 S/A SERVICE TRUCK (A66091)
2006 GMC T7 4X2...
2013 Ford Taurus AWD Sedan (A64557)
2013 Ford Taurus...
2023 KOMATSU D51EX-24 CRAWLER DOZER (A65053)
2023 KOMATSU...
