Shear Bolt ?
/ Shear Bolt ? #1
pstoudenmire
Abbeville SC
Kubota MX5100
I need to pick up a spare shear bolt for a subsoiler. What grade bolt do I need? I was told grade 2, but I wanted to check with those in the know.
/ Shear Bolt ? #2
Shear bolt specs are application dependent. Your subsoiler operator's manual or parts catalog should spec the bolt.
Since you don't state the make and model of your subsoiler, you can't get an accurate answer to your question (as posed) here.
/ Shear Bolt ? #3
ditto what rick said. if it has the correct bolt in it now and is sae.. count the hash marks on the hex head... none=gr2 3=gr5 6=gr8
/ Shear Bolt ?
Thanks, It's an old cat. 1 subsoiler. I don't remember seeing a name on it, but I'll look closer tomorrow. I don't know if it's the original bolt in it now or not, but I'll check it tomorrow also. I have about 5 ac. of pasture that I want to subsoil and there are a good many trees (large roots) and rocks in it. I'd rather play it safe than damage the subsoiler or tractor.
/ Shear Bolt ? #5
Then start with a soft bolt.
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
AUCTION STARTS HERE @ 9AM (A63291)
AUCTION STARTS...
Ford F-450 (A63689)
Ford F-450 (A63689)
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
207280 (A52708)
207280 (A52708)
