shear bolts B2782 snowblower
   / shear bolts B2782 snowblower #31
I just went to the dealer to buy some additional shear bolts. The bigger bolts for the auger are 5/16 by 2 1/4" and are #5. The owner's manual says these are special bolts. Presumably what makes them special is that they have a little grove about 1/4" down from the head.
The bolts for the impeller are #8 which is what the owner's manual states, nothing special apparently.
For those of you who say they are too hard for this job, I can only say that I have had 3 auger bolts shear and one impeller bolt shear and they did their job perfectly. They are very easy to replace, now that I have had some practice.
8 auger bolts, washer, nut and 4 impeller bolts washer and nuts cost - $19.97 :(
Pricey to be sure, but you know you've got the right ones at least.
Chilly
   / shear bolts B2782 snowblower #32
I use cheap 1/4 inch bolts and Nylock nuts on my Luck-Now 52" 3pt snow blower behind my BX23. I'd much rather break the bolts than the next weakest link. I have a gravel driveway and, believe it or not, a dirt pasture / barn area.
I carry extras and the wrenches in my jacket and can replace them in about 2 minutes.
   / shear bolts B2782 snowblower #33
I sheared the grade 8 pin in the fan...4 pins cost $1.82 Canadian. Taxes in..
   / shear bolts B2782 snowblower #34
I can change an impeller shear pin quicker than anyone in the GREAT WHITE NORTH! That's because I have changed a ton of them!
Dealers, mechanics cannot solve this problem. I'm about ready to throw in the towel! :confused:
   / shear bolts B2782 snowblower #35
Just found this thread while search for information on how to disassemble the B2782 snowblower to sand and repaint the rusted parts. Anyway, when I first got my snowblower I was constantly breaking the shear bolts so I investigated what was needed and collected all the information about the bolts to make sure I did not use the wrong bolt which could lead to catastrophic failure if the bolt did not give before internal gears. So for all to review I am adding the .pdf file here (hopefully it will upload):
  • EverythingSHEARBOLTS.pdf
   / shear bolts B2782 snowblower #36
Safety wire or bolt instead of shear pin. How strong/weak is the next shear pin in the drivetrain?
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2018 Ford F-250 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-250...
20' Sea Container (A55272)
20' Sea Container...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
19010 (A55851)
19010 (A55851)
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
