shear pins
   / shear pins #1
jimbo64
went to tractor supply and one other farm supply store to buy shear pins for my bushog and they both said to use 7/16 or 1/2 number two bolts as shear pins. old pins were shear pins with a grove in them to break under pressure. Will #2 bolts shear as easily- 7/6 or 1/2 inch #2 bolts seem pretty substantial
and i really not interested in tearing anything up=neither store carried "shear pins".
   / shear pins #2
#2 bolts aren't a very strong grade. I broke a shear pin on a bushog, and replaced it with a grade 5 bolt. Broke that bolt so I used a grade 8, and broke it too! The tractor was a tc30 running a 6ft bushog in tall grass and thorns (all it wanted) Still not sure if something was wrong with the bushog or what caused the repeated pin/bolt breakage (not my tractor)
I wouldn't be worried about a grade 2 bolt being too tough to use as a shear pin.
   / shear pins
thanks for the input carpenter383- is half inch to big or should i stay with 7/16
   / shear pins #4
I picked up a 3pt snow blower a week ago. I knew I was going to go through a bunch of shear bolts so I wanted to stock up. My manual made reference to #2 grade bolts
   / shear pins #5
You better buy them by the bagful.. I run only grade 8 bolts and I still break plenty of them.
   / shear pins #6
I would use a 1/2 in bolt if thats what it takes to fit the hole tightly. You don't want to have slop in the holes where the bolt goes through.
2018 RoGator 1100C (A56436)
2018 RoGator 1100C...
6ft Teakwood Cowboy (A57454)
6ft Teakwood...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
Chemical Containers Tank (A57148)
Chemical...
Honda utv cart (A56859)
Honda utv cart...
Utility Cart (A59228)
