Shop Walls
/ Shop Walls #61
You got through the tough part, making your decision after all our suggestions. :thumbsup: Good luck with your project and don't forget to post pics! We all like to see how things turn out.
/ Shop Walls #62
Decision Made: I'm going with plywood.
Lots of great suggestions. I really like the Puck Board idea, but not easy to source. 3/4" plywood sanded on one side and painted is the way I'm going.
It will be 1/2" off the concrete floor to avoid direct contact and minimize moisture. I will also paint the plywood front, back, and all edges to seal it.
Thanks everyone.
Doug
Are you going to do anything to seal the 1/2” gap? If you are insulating your walls, that’s a nice little entrance for rodents to make a home out of your insulation. They’ll find a way in eventually, but a gap like that all over is an open invitation to free room and board!
/ Shop Walls #63
If it is standard stud construction, the bottom plate will accommodate that
/ Shop Walls #64
Thanks everyone.
Doug
Sounds good!!!! Make sure to post pics during the process and the finished product!!! Thanks for the update!!!
/ Shop Walls #65
Yep. I just left a 1/4" gap and then filled it with caulk. I didn't want a crack for a welder or torch spark to get into.
Schuler 125B Feed Wagon (A66408)
Schuler 125B Feed...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
(4) Yetter Trash Wheels and Cutter (A65640)
(4) Yetter Trash...
Hydraulic Auger Mini Skid Steer Attachment (A64553)
Hydraulic Auger...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
