Shopping for a generator
   / Shopping for a generator #1
Hunter29
Michigan
Kubota B2920
So its going to be one of these, the kubota is just shy of 10kw it will put out 36.5 amps at 240v with a max of 41amp peak/ head room, but pretty much same as what I have now.
It weighs 650# , takes 4.5 quarts of oil and is the same motor as in my tractor ..
The Perkins will put out 42 amps with a peak of 44 amps, so a solid 10kw unit, it weighs 745# and holds 8 quarts of oil of which they spec synthetic 10w-40
They cost the same, kubota easer to maintain , same parts as the tractor, lighter , may even pickup with my loader, less oil so less cost, even thou more oil the better this is good enough as I'll change it once a year at 20 to 40 HRS..
The perkins is 100# heaver , twice the oil at higher cost, but its a bit stronger, but again I don't really need the extra power. Its also a little bigger, burns a bit more fuel and is a few db louder.
What do you think? the Kubota has a better warranty..
Perkins... Perkins 10,000 Watt Diesel Generator
Kubota... Kubota 9,875 Watt Diesel Generator
   / Shopping for a generator #2
Be sure to also look at the Isuzus Central Main Diesel sells. When I was shopping, they had the lowest fuel gpm numbers. They come from GPP (Global Power Productsョ - Diesel Generators). You can get the detailed specs on that site. To me, fuel consumption numbers would be a key factor.
   / Shopping for a generator #3
Couldn't go wrong with either one ! Would be the Kubota for me too !
I really like the kubota, it's small and kinda cute, hehe.. tough choice but I am leaning to the Kubota.. but More input would be great so others chime in please...
   / Shopping for a generator #6
I bought the same Kubota a couple of years ago. It is a very nice unit and performs extremely well. I can power my whole house with no problems, running 3 heat pumps + 3 refrigerator/freezers. On outages I shut down the HPs and turn on the electric HWH to charge it up for a day's use (it is an 80 gallon unit). That takes about an hour. On average I use 0.3 GPH of diesel to run the house during an outage.
I got the Kubota as well so that parts/filters/etc would be common with my tractor.
If you order one, you can get a start/control panel for a couple of hundred bucks extra. It does preheat, cooldown, fault detection, etc and shows frequency, hours and other data. It came all wired in by Central Main. It provides a 2-wire start/stop for "remote" starting.
Great unit.
Paul
   / Shopping for a generator #7
I live way out in the middle of nowhere. Nearest neighbor is 4.5 miles away. I have a little 3500 watt Honda generator - more than enough to power the pellet stove, refrigerator & freezer. I can bucket water out of my lake. The wife and I have lived here since 1982 and in those 32+ years have NEVER had to use the generator. We have power failures - about once every 3-4 years. The longest outage was 10 hours about 18 years ago. We belong to a private utility company and I guess you could say we have fantastic service. We, also, have never had a major natural disaster that would create a long outage.
   / Shopping for a generator #8
I have a similar situation, with a 4400/5000 watt no-name unit that I bought from Harbor Freight in 1997 for $279 and free shipping. It has been used for one 5 day power outage and for building an addition on the barn. It has maybe 100 hours on a B&S engine. At this rate I'll be dead long before it wears out. I also have a little 1000 watt 2-cycle camp generator that is whisper quiet. It will run the freezer and refrigerator at the same time, or the refrigerator and the entertainment center/satellite dish.
With wood heat and low head gravity feed water, I don't even bother to get the generator out until the second day of a power outage. We just cook on the wood stove, or in warm weather on the deck with a propane camp stove. My wife has commented that the comfort level of our home doesn't change much when the power goes out.
The big advantage of 19th century technology is that it works fine and doesn't require much in the way of external inputs.
   / Shopping for a generator #9
I didn't see the option for an automatic transfer switch with the Perkins? And I didn't see the option for a remote start with the Kubota?
I'm imagine you could get either aftermarket though.
How will you be enclosing it? Will you be using it for a whole house generator? Are you going to tie it in with automatic transfer?
On the Kubota, it gave the option for a 100amp transfer switch. Does this mean you can't use it for a 200amp panel? Or do you just get a second transfer switch to make 200?
   / Shopping for a generator #10
I think the idea is that you pick several circuits that you deem critical, and route those through the transfer switch. Remember it only outputs 40 amps give or take...
If you didnt want to pick an choose then I would just go with a manual generator disconnect breaker and back feed the entire pannel.
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2015 FORD F150 XL TRUCK (A51406)
2015 FORD F150 XL...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A55745)
2005 PETERBILT 379...
UNUSED FUTURE STB47 - 47" TELESCOPIC BOOM (A54757)
UNUSED FUTURE...
Giyi 72" 4-n-1 Bucket (A53316)
Giyi 72" 4-n-1...
UNUSED FUTURE MCLG60-43" MINI CURVED WOOD GRAPPLE (A54757)
UNUSED FUTURE...
