Should I even consider a 7' cutter?
   / Should I even consider a 7' cutter? #11
Really ... put that cutter in some true 18-24" heavy bahia and see how that works.
I think my tractor with 29hp at the pto would also do fine in that with an 8' cutter.
Everyone seems to think you have to run 4-6mph wile cutting and if you can't you are under powered.
I have a 6' cutter and have cut everything imaginable. Slowest I've ever had to go is 3rd gear (3mph). An 8' cutter in the next gear down would power it just about the same
   / Should I even consider a 7' cutter? #12
I've got 30hp at the PTO, and I could see going from my 5' to a 6 footer, but 7 or 8 would be wagging my dog unless it was hitch mounted. Even if I could power it properly, it'd be manhandling me every time I raised it. Your manual should have ballast codes and an upper weight limit for implements listed. I'd refer to those and try and get your expectations matched up with the manufacturers.
   / Should I even consider a 7' cutter? #13
All depends on the cutter.
I currently run a 1100# 6' cutter.
A medium duty 8' twin is ~150# more, but 2' shorter. I think the lighter but longer HD 6' cutter would be more likely to wag the dog
   / Should I even consider a 7' cutter? #14
Well I guess it was a dumb question, I'll take that as a yes it's too big lol...
Maybe I'll save my pennies for a dual spindle 8'er.
most of the time, a dual spindle 8 weighs less and is easier to pull than a huge 7'
The tractors lift is rated at 2750lbs on the ends. I'd really like to have the dual 8' but it's going to be 1000$ more than the 7. There is a weight difference, (1200 for the 7, 1350 for the 8) though obviously the 7 will feel much bigger sticking way out there. The 7 is rated for 50hp min, the 8 at 45hp min and my tractor comes in at 47.3 at the pto. They also both have dual tailwheels. I would basically use the 7er as a pull type though without lifting it very often, and by the same token if I have really heavy stuff to mow I do still have my old 6'er...
Then again I may just wait till he gets some heavy 6'er in.
   / Should I even consider a 7' cutter? #16
remember.. an 8' dual spindle only sticks out a max of 4' plus tail wheel.. the 7' sticks out 7' plus tail wheel. that 150# extra is nothing compaired to the leverage that nearly twice as long mower will have. ( unless it is also a dual spindle mower of some sort. ) that weight seems low in comparison to the 8'..
   / Should I even consider a 7' cutter? #17
I had a 7' (John Deere 709) I ran with a John Deere 2355 (55 pto hp).
I now run a 6' (John Deere MX6) behind a John Deere 4120 (35 pto hp)
Cutting the same pastures the same way I would bog down and have to stop and let the cutter wind back up all the time with the 7' and 20 more HP. I rarely ever bog the 6' and the smaller tractor.
Thanks guys, I have pretty well eliminated the 7'er from consideration. The cheap price I was offered was the main reason I was interested but you all have confirmed what I thought to begin with. In the meantime my dealer has located some heavy duty 6'ers and he has an 8' dual spindle that I still may go with. The 6'HD model is available with one or two tailwheels, not sure why I'd need two on a 6'er but are there any advantages with 2? Only thing I can think of is 2 would give a little less clearance when turning??
Oh and BTW I saw a single spindle 8'er, I didn't know such a beast existed! I don't know if even the old 4020 would handle that thing...
   / Should I even consider a 7' cutter? #19
I think that 29 hp at the pto to run an 8 foot cutter is a pretty bold claim. There is a serious difference between spinning the blades and actually being productive using a cutter to its potential. I agree that mowing at half the speed with double the size cutter is still technically covering the same acreage but if you constantly have to gear down then you should have gotten a smaller cutter. I currently have 69 pto hp on an Mx10 cutter and rarely do I ever even use the e pto option because I need more hp. Even when clipping pastures the slopes don't make it feasible. When I get into cutting vegetation over the height of the front tires, I'd kill for another 20 hp on the pto and I'm well over the recommendation of 5hp/ft rule of thumb.
   / Should I even consider a 7' cutter? #20
29 hp for a 8 foot cutter is ridiculous. It might work in very thin grass at 2 mph, but it is still putting lots of undue wear on a tractor .
CFG Industrial MX15RX (A53316)
CFG Industrial...
2004 Winnebago Suncruiser IPG37B 38FT Class A Motorhome (A55758)
2004 Winnebago...
Hesston PT-7 Haybine (A50775)
Hesston PT-7...
2008 Ford E-350 Versalift Vantel29N 29ft Bucket Van (A55788)
2008 Ford E-350...
2016 Ford F-150 Pickup Truck (A54814)
2016 Ford F-150...
