Should I even consider a 7' cutter?
   / Should I even consider a 7' cutter? #51
My mowing jobs are rarely over 5 acres each. But I do many so I have mowed about every condition imaginable.
I find that most of my work is one of 3 types.
1. Commercial accounts around factories or whatnot. That own a good bit of land but don't want to pay to kept it all finished cut. These usually get done anywhere from 3-5 times a year. Not hard cutting at all doing it that frequently. I am typically mowing 6th gear with power to spare. Only have to slow down for rough terrain. A larger mower would allow me to get done faster.
2. Horse pasture maintenance. Knocking down the grass and weeds the horses cannot keep up with. This is never very thick or tall. But usually pretty bumpy. Again, power is no issue so a larger cutter would still allow me to get done sooner.
3. 1 off jobs that are usually either overgrown laws around a foreclosed house that finally sold or a lot that people want cleared to build a house on. The ones that are overgrown lawns I am usually going slow because god only knows what was left out there, where the well and septic are, decorative rocks, etc. Power is again not an issue cause I am going slow and cautious. The lots that once used to be a field but someone wants to build on, are the only time I "may" have to go slower for power reasons.
In most of my mowing, an 8' would get me some quicker. In the few that I lack power on, I would just go slower but still finish in the same timeframe. So a larger cutter wojldnt "hurt" my bottom dollar
I use a 7' mower on my tractor, I just don't use the top link on the 3 point (I have no reason to lift a 7' mower 2' or 3' off the ground). In light areas I use the all the 7', in any heavy stuff I just move over so I'm only cutting 5'.
May I ask which tractor you are using with the 7'er? I'm guessing the 6640? The way you describe using yours was pretty much what I was considering doing to keep the weight off the tractor, or at least keeping the top link from holding the weight. I'm not sure I want to go that route just yet though. I did get a chance to look at the dual spindle 8'er today and it is a nice piece of equipment. Really no rush to decide just yet I guess...
   / Should I even consider a 7' cutter? #53
With my MF2135 gasser, here is a video, it's not that clear but those weeds are mesquites.
Wow that is impressive, thank you for sharing the video. Good looking tractor btw! Forgive my ignorance, is it the same HP as a 135?
I just may reconsider going the 7' route. My dealer seems to think it would be a good match to my tractor, in fact better than the 8 in his opinion. He offered to let me hook up to each and try them out. Honestly if I mow my areas even just once a year it won't be terribly thick, probably no worse than the mesquite in the video. And as suggested if I need to get in the woods my 6'er is ready to go. I may take him up on the offer and at least check them all out..
   / Should I even consider a 7' cutter? #55
That's how I get all my hay. 4 neighbors. I'm responsible for all seed and fertilizer but I get all the hay. Must be cut twice a year. Spring goes to hay. If I need more the fall will be baled if not brush hogged. I go back around after spring cutting and brush hog field edges. Probably the thickest stuff I mow all year. I only try to mow behind the cows at home. Unless seed heads get ahead of cows then I'll knock them down. But that's mowing at like 16-18 inches.
Yep. Free hay is good. Free maintenance of the fields is good for the owner. Some of them pay to have their yards done so they appreciate not paying to have their fields cut.
   / Should I even consider a 7' cutter? #56
Yep its the same as a 135 practically, its got the old Continental Z134 with a earth shattering 39hp! In that video that was the first time I had the shredder hooked up to that tractor (I had the top link on it). Now I just pull it around with just the lower lift arms, and the rear rides on the wheel, it works great that way. The 6640 picks it up like its not even there.
Man I gotta say I have a new respect for the little MF gasser!! I plan to get a hydraulic top link so as I understand in the float position I would essentially be using the deck as a pull type cutter, same as you. My tractor has almost 1/3 more hp so for the same type use I should be ok, and all the weight wont be on it. Now if I could only have one cutter I'd stick with a 6' but it will be nice having both options I think.
Of course theory is just that until it actually works! But when I get a break I'll go hook up to the 7 and 8 and get a feel for them and go from there.
Thanks to everyone for all the input! And any further discussion is great as well, it may help others as well as myself. I'll keep you all posted on how the demo goes.
And the hay idea is a great one, I've been considering it myself. I just hate to commit my land for that use right now as I have other uses at the moment.
   / Should I even consider a 7' cutter? #59
I bought the tractor for $1500 not running (figured if it was junk I could easily recoup what I paid for it). I was really skeptical of the Continental gasser (I wanted the Perkins AD3.152 diesel). Now that I have tuned up, it needed a tune-up when I shot that video. Despite it needed a tune-up I was actually impressed with what that little Continental Z134 could do. But I'd still get rid of it in a second for one with the 3 cylinder Perkins diesel.
   / Should I even consider a 7' cutter? #60
I have a 10 acre field out front that a guy hays, I dont get rich off it but it pays $600 a year, and it stays mowed.
200 Gal. Fuel Tank (A53316)
200 Gal. Fuel Tank...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
378260 (A54865)
378260 (A54865)
2021 Kubota SSV75 (A53314)
2021 Kubota SSV75...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
Detroit 6 Cylinder Power Unit (A53314)
Detroit 6 Cylinder...
