Silt Happens!
/ Silt Happens!
Here's a picture of about 10 yd of dryed silt pushed up into a pile from cleaning the pond sides. I haul this off and build terraces out of it. If I line the terraces with rock, hopefully the silt won't end up back in the pond the first time it rains. /forums/images/graemlins/tongue.gif /forums/images/graemlins/smirk.gif
/ Silt Happens! #82
</font><font color="blue" class="small">(
99% of the water will come down the chute on the left side. I'm going to shape the sides into more of a "V" and cover the bottom with rock. On the right side, I plan to collect the water that runs off the hillside and let it drop over a small rock waterfall.
)</font>
Jim,
From what I've read and personally experienced, most of your silt will enter your pond the first season it rains. After that, the vegitation will grow back and the level of silt will decrease dramataclly.
This is a concern I have with my lake I'm building, and it happened with the two other ponds I dug.
One of the ponds are on the land I sold with the container barn. The new owner brought in a crew to create some pastureland for cattle. They also noticed the silt starting to build up in the pond.
First they dug the silt out with a trackhoe, then they dug a pit before the pond along the main route the water traveled before entering the pond. It was sort of like your situation. The water travels to a funnle type area, then int to pond.
The pit they dug caught the water and allowed a large amount of silt to settle in the pit, then the water would enter the pond in much cleaner state.
We've only had a few rains since he bought the land, but he's had to clean out the pit each time due to the amount of silt he's cought in the pit. Anything that stays in the pit is somehting that wont go into the pond.
I'm gonna try somehting like that on my lake, but allot longer to see if it helps. I'm also going to dig a few pits on the bottom of the lake along the shoreline to catch the silt from the first few seasons of rain.
Thanks for all the updates and pics. Sure looks like it's gonna be a real nice pond when your done with it!!!
Eddie
/ Silt Happens! #83
Jim seeing just how small your TC45D looks in the picture sure puts the size of your project in real perspective.
I agree with Eddie in the respect that after finishing our pond the engineer told me that the single most important thing to do next was to establish grass on the perimeter. The first couple of heavy rains that we got before the grass came up clouded the water showing that silt was being washed into the cavity. But once the grass came up the water remained clear even after the heaviest rains, a sign that the grass was doing its intended job.
/ Silt Happens!
</font><font color="blue" class="small">( I agree with Eddie in the respect that after finishing our pond the engineer told me that the single most important thing to do next was to establish grass on the perimeter. )</font>
Absolutely! The grass has to be established, but you really have to finish all your dirt work first or you are just scraping off the seed. I'll probably first plant wheat or some other vegetation that will germinate and grow quickly. Then, I'll try to establish some bermuda for the final ground cover grass. In the meantime, I plan to use rocks as a filter and retainers for sand and silt, maybe even a few single-high crosstie barriers or straw hay bales. There's no way to keep all the silt out of the pond, but at least I can cut a lot of it down by covering the ground in rocks (and even a few loads of crushed rock if needed). My wife's land has lots of flat stone in approx. 1' ovals up to 3' ovals, so I'm sure I'll be rock haulin' a lot over the next few weeks. It's just hard to know when I should stop working the dirt and start building mud barriers in preparation for some rain. /forums/images/graemlins/smile.gif
/ Silt Happens! #85
<font color="blue"> It's just hard to know when I should stop working the dirt and start building mud barriers in preparation for some rain. </font>
If its anything like most years, we will go from bone dry to overflowing your dam in a few days time. And vice versa. 2004 was one of the wettest years on record. I think it was 50+" rain. 2005 was the 5th driest on record, less than 20". /forums/images/graemlins/crazy.gif
/ Silt Happens! #86
<font color="blue"> 2004 was one of the wettest years on record. I think it was 50+" rain. 2005 was the 5th driest on record, less than 20". </font>
Well don't blame that on my office ... we're in advertising - not production! /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif (nws)
/ Silt Happens!
Well don't blame that on my office ... we're in advertising - not production! /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif (nws) )</font>
Okay... How about a little truth in advertising. /forums/images/graemlins/smirk.gif
Oops! Sorry... lost my head there for a minute. You never get truth from a weather guy. /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
/ Silt Happens! #88
It's easy to say this from my chair, but I think if I were going to haul and lay anything around the perimeter, I'd choose sod rolls. More expensive than free rocks, but you only have to lift them once instead of twice. Just one row around the perimeter will trap a lot of runoff. A second row several feet up the bank would trap even more. Then you have the grass and no rocks to remove later when you're tired of hitting them with the mower.
You've done a great job so far, so I'm confident that you'll get the runoff problem solved, too. Good luck!
- Just Gary
/ Silt Happens!
Gary, I'd love to put sod around the pond, but my problem is maintenance of the sod. In its infancy, sod requires a lot of water and almost daily maintenance to get it established. After it starts to root and grow, sod requires watering on a regular basis. By using native grasses and then adding coastal bermuda, I can reduce the amount of maintenance required to keep a healthy ground cover and root system.
With our ponds here in North Texas, we get rain early in a season and then the pond has to hold that water through months of dry season. That's the normal routine. This year, we didn't get the rain and we have an extended dry season. Grass that normally stays green is dry and brown. I just think native grasses have a better chance of returning once some moisture falls.
Also, most of the rocks and sand I'll use will have flowing water or be covered in water for several weeks during the wet season. Most grass also doesn't do well under water. I plan to have a sandy bottom wading pond when its wet and a sandy "beach" area as the water recedes. At least that's my plan for now. We'll see how well I do at getting that accomplished. It's all a lot of work and I am going to rely heavily on my tractor for some help. /forums/images/graemlins/cool.gif
/ Silt Happens! #90
R/C tractors /forums/images/graemlins/grin.gif There are a couple guys who take 1/16 Ertl tractors and turn them into R/C models. Here is One of them
And another
In Action
Also, Ertl has made some before and just recently released a 1/10 scale John Deere 9520 and 9620. It is a monstor of a RC. I attached a pic of it
/ Silt Happens! #92
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Where did you get that little toy NH? It almost looks real except that it's so tiny. )</font>
Christmas tree ornament... /forums/images/graemlins/laugh.gif )</font>
:::::::::::::::::::::: <font color="blue"> :::::::::::: </font> :::::::::::::::::::
You can't have to many Christmas Tree Ornaments
/ Silt Happens! #93
I planted mine in rye grass and Bermuda grass mixed with fertilizer from the CO-OP. I planted inside pond, banks and the leave. Then I paid someone to blow chopped oat straw. I also laied bails in the main water channels.
John
[image]
[/image]
[image]
[/image]
John
/ Silt Happens!
</font><font color="blue" class="small">( Also, Ertl has made some before and just recently released a 1/10 scale John Deere 9520 and 9620. It is a monstor of a RC. I attached a pic of it )</font>
Oh yeah! I can see me spending entirely too much money on that. I already have too much time and money in RC boats. /forums/images/graemlins/blush.gif
/ Silt Happens!
</font><font color="blue" class="small">( Jim - Just out of curiosity, how is the large lake holding out? )</font>
Bill, it's down 4-1/2 to 5 feet. I'd say over half of its normal capacity. The waterline has receded about 20' out from my bank and probably the deepest spot in the lake is just over 6' deep. I'd guess that 1/3 of the surface area has dried up, so about 10 acres under water. /forums/images/graemlins/frown.gif We have been driving the Mule and my tractor around on the little swampy inlet across from the ponds for over a month. I guess I should take the opportunity to dig out beaver lodges, but I just haven't had time for that yet. /forums/images/graemlins/smirk.gif
/ Silt Happens!
</font><font color="blue" class="small">( I planted mine in rye grass and Bermuda grass mixed with fertilizer from the CO-OP. I planted inside pond, banks and the leave. Then I paid someone to blow chopped oat straw. I also laied bails in the main water channels.
)</font>
Very nice, John! Thanks, that's just what I had in mind, but I'll probably start with wheat in the spring because rye dies out so quickly when temperatures get into the high 80's.
/ Silt Happens!
I guess it's time for an update on my project. I've been snatching every chance I can to work on the pond and have divided my time about equally between smoothing out silt and digging down the sides of the pond where the dozer didn't get before he had to go to another job. The silt pile has been brutal. On top it is dry and dusty, but underneath it is still pudge. I've been leveling off with my tractor, but some of the silt "boulders" are 3' in diameter and as soon as you cut into them they are just pudding in the middle. I've had to push myself out of so many stuck spots using the bucket that I'm a virtual expert, it's second nature. One of these days I'll get stuck when I don't have the loader on and I won't know what to do. /forums/images/graemlins/crazy.gif /forums/images/graemlins/laugh.gif
This week, I took two vacation days to try and get more work done in the pond and take care of about 1/2 days worth of business (getting my new bride her military dependent ID card). Thursday was a perfect day for working in the pond and Kathy came down to take some pictures of me getting "down and dirty." /forums/images/graemlins/smile.gif
This first picture shows how I use a trench to cut down through the silt. By making a trench with my bucket, it stabilizes my tractor on the downslope so it doesn't tend to crab sideways as the rear wheels spin, pushing the bucket into the silt. As you can see, the bank is quite steep and the silt is still very deep when I started. I've worked my way all around the dam doing this same routine and moved hundreds of yards of this red gummy-clay silt. Many times I've had to stop and use a shovel to clean out my bucket because the silt just refused to come out. /forums/images/graemlins/tongue.gif
1st picture is my trenches...
/ Silt Happens!
Here I go... into the trench. Once you commit, there is no turning back. /forums/images/graemlins/shocked.gif
/ Silt Happens!
A close-up of a dirty guy in a dirty TBN ballcap on a very dirty tractor.
I thought I had died and gone to heaven. /forums/images/graemlins/wink.gif
/ Silt Happens!
This "elevator" is going down...
7' Road Blade (A62613)
2016 Caterpillar 304E2 (A64126)
2016 Caterpillar...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
ATS Mini Excavator (A66408)
ATS Mini Excavator...
2019 HYDREMA MX18 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX18...
2022 SANY SY35U EXCAVATOR (A63276)
2022 SANY SY35U...
