Single acting cylinder help
   / Single acting cylinder help #21
Just about all FEL valves come with load check. They simply keep the cylinders from dumping fluid, when you are shifting the spools. On a FEL valve with float, you should be able to raise the cylinder, and when you want to retract, go to the float position and that opens both cylinder ports to the return path. You can test this by connecting a hose to the return port, and put the other end in a clean bucket, and play with the FEL levers on a double action cyl, or a single action cyl to see what the results are.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
BELSHE DT-235 (A53843)
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
1995 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
1995 POLAR TANK...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
