Sizing a Backhoe Thumb Cylinder
   / Sizing a Backhoe Thumb Cylinder
bindian said:
I agree with you. :) It also means Bradco's hyd thumb and bucket can function exactly like a clamshell bucket. That is all........not for or against it. ;)
hugs, Brandi
Yeah, it's kind of an "interesting but moot" point. It is what it is. One could imagine situations where one or the other configuration might have benefits over the other, but there is little sense in messing with the excellent, powerful Bradco factory design. :)
Dougster
   / Sizing a Backhoe Thumb Cylinder #62
Dougster said:
....there is little sense in messing with the excellent, powerful Bradco factory design.
...unless you wanted to save a BUNCH of money. 600 clams for just
the hyd cyl, indeed!
dorfkrug said:
...unless you wanted to save a BUNCH of money. 600 clams for just the hyd cyl, indeed!
I was referring only to the design, geometry and strength of the Bradco thumb (which is really quite good)... definitely not to the cost of the various add-on components to go hydraulic when obtained from Bradco. :cool:
Dougster
   / Sizing a Backhoe Thumb Cylinder #64
Here is what ABC Groff has for prices. Bare in mind each pin has two washers and snap rings. I think there is a typo on the $1,20.00. I think it should read $1200.00. All the parts below total $524.18 for a cylinder installation. So I guess the $573.82 my Mahindra dealer quoted me is for all the same parts.
hugs, Brandi
Please see prices list below. All parts would be available in 1 week
Thanks,
Ike
Sent: Friday, July 20, 2007 7:23 PM
Subject: Hyd thumb kit & parts
> Please give price and availability for these items listed below for
> Bradco's hydraulic thumb for their 509 & 511 Backhoes
> Thanks, Brandi
> # 15780 Hydraulic Installation Kit $1,20.00
> # 16955 Cylinder Assembly $431.00
> # 16702 Pin 1.25" x 5.13" $37.33
> # 57693 Washer $1.33
> # 1652 Snap Ring $2.27
> # 16703 Pin 1.25" x 3.44" $41.45
ABC Groff Inc
110 S Railroad Ave
New Holland, PA 17557
Tel: 800-346-8319
Fax: 717-354-5159
website: abcgroff.com
Good God, those pins are expensive!!! :eek: What's up with that??? :rolleyes: Are they gold plated??? :D
Cylinder itself is not half bad compared to aftermarket. I could go for that just to keep the delivery time under control. :eek:
Did they mention whether these are Bradco list prices vs. discounted???
Dougster
   / Sizing a Backhoe Thumb Cylinder #66
hugs, Brandi
Thanks,
Ike
> Thanks, Brandi
ABC Groff Inc
110 S Railroad Ave
Tel: 800-346-8319
Fax: 717-354-5159
Correction on price of Bradco hyd kit for 509 & 511 thumb. Ike with ABC Groff just emailed me with a price correction of $1020.00 for kit #15780.
It getting better all the time. I can live with these prices. :cool:
hugs, Brandi
hugs, Brandi
Easy for you to say! :) Just wait until you suddenly find yourself (semi-) retired! ;)
Dirt Poor Dougster
   / Sizing a Backhoe Thumb Cylinder #68
Dirt Poor Dougster
Dougster,
Check out the Prince Wizard cylinders again. It would seem the cylinder ends need to be welded on, thus raising their cost. The Bradco cylinder from ABC Groff is not that much more after paying a welder to do prescision welding. Yes, they want a lot for the pins. I can get 1.25 bolts from my local mill supply for around $9 each and drill a hole for a cotter pin through the nut and bolt.
The kit cost is in my reach when (?) my son pays me back for loaning cash for down payment on his used Mustang.
hugs, Brandi
bindian said:
Dougster, Check out the Prince Wizard cylinders again. It would seem the cylinder ends need to be welded on, thus raising their cost. The Bradco cylinder from ABC Groff is not that much more after paying a welder to do prescision welding. Yes, they want a lot for the pins. I can get 1.25 bolts from my local mill supply for around $9 each and drill a hole for a cotter pin through the nut and bolt. The kit cost is in my reach when (?) my son pays me back for loaning cash for down payment on his used Mustang.
hugs, Brandi
Hi Brandi - I'm not following exactly what you're saying about the "Wizards." Hope I didn't mislead you, but my understanding is that the Prince Wizards come 100% assembled and ready to use straight from the factory with whatever ends and other options you choose. That's probably what makes them take so dang long to order! :rolleyes:
Is my understanding incorrect? :confused:
Dougster
   / Sizing a Backhoe Thumb Cylinder #70
Dougster
Dougster,
Read the PDF spec sheet on Wizard cylinders on the Prince website, click on ...Catalog Pages. See page 2 in the middle of the page in a note that reads...............Important: Extend rod before welding on end fittings. Seal Damage will occur from excessive heat.
hugs, Brandi
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A55788)
2003 Ford F-250...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A55788)
2015 Ford F-550...
2015 Chevrolet Tahoe (A55853)
2015 Chevrolet...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
