Here is a link that goes into depth explaining it all
EMCE | Every Winch a Winner
Physics
Power
As*stated power is expressed in kW (kilowatt). In physics Watt can also*be expressed in J/s (Joules/second). Joules can also be expressed in Nm (Newton metre), therefore Power can be expressed in Nm/sec.
This makes power more understandable, since we know the required*Nm (line pull x effective drum radius) to move the load and the required speed at which the load has to be moved. The higher the speed (at a given load), the more power we need.
The calculations behind this look as follows: P(kW) = F(N) x V(metres/min) / 1020 x 60** In which P = power in kW, F = Force (line pull) in Newton, V = Line speed in metres/min, 1020 is a constant and 60 is a translation from minutes into seconds (Nm/sec).
Torque
With the required amount of power (kW) determined, the amount of torque (Nm) involved in the application must be determined. Depending on the effective drum radius and the load the torque at gearbox and motor level can be calculated. The amount of torque at gearbox level is important to make sure a sufficiently strong gearbox is chosen, and at motor level to make sure the load can be actually moved.
The effective drum radius used in this calculation is the distance between the*centreline of the active rope layer and the centreline of the drum. For winches with only one layer of rope this is a constant factor. For winches with multiple layers the distance is a variable, and depends on the amount of rope wound on the drum. Please*see Fig. 3-2 for the influence of the number of rope layers on the effective drum diameter.
https://emce]
a) Drum radius proper -*b) Effective drum radius with one layer of rope - c) Effective drum radius with four layers of rope.
Note:*The rope diameter (required for the above calculation) follows from the nominal winch load, the required safety factor and the type of rope selected.
