Skidding Winches
   / Skidding Winches #131
Fransgard has really changed their design, mine doesn't look nothing like that, has no feet so I don't have to worry about it running away. How far back in the last century is that?
I bet they "hobble" them, when they take them off their tractor! lol
SR
   / Skidding Winches #132
Not sure but early 80s maybee, the feet is a very good solution on a small tractor, it it had a blade I loose almost all ground clearance.
   / Skidding Winches #133
I have a Norse 350 -- new last fall. A god fit for my 40 HP CUT.
   / Skidding Winches #134
You have å hinged blade on yours
   / Skidding Winches #135
Hydraulic, a bit slower than pto operated but I am not in a race. I really enjoy the wireless remote being alone.
   / Skidding Winches #136
You might have the oldest working pto tractor winch. More ground clearance is always good, I have 16" and wouldn't want a inch less.
   / Skidding Winches #137
Awww jeez, mine's got feet too, and I never even considered it running away. Now I've got something else to worry about!
Should be all set if you have it well trained from being used often, but if you leave it in grown up field for too long, might run off then.
   / Skidding Winches #138
Mine old? This is old
   / Skidding Winches #139
An quite common older design
   / Skidding Winches #140
On this you see the very simple construction on the winch with the rubber wheel. Its a factory design.
2005 CHEVROLET EXPRESS CARGO VAN (A53426)
2005 CHEVROLET...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
RYOBI 18V ELECTRIC 13" PUSH LAWN MOWER (A51248)
RYOBI 18V ELECTRIC...
JOHN DEERE 5075GN LOT NUMBER 114 (A53084)
JOHN DEERE 5075GN...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53472)
2022 Quick Attach...
