Sleeve Hitch
   / Sleeve Hitch #11
<font color=blue>Sounds like I could fabricate something with just a block of metal with a hole through it bolted to the frame. Sound right?</font color=blue>
That's what I was thinking. I haven't yet taken a good look at mine to see where I might attach it. One possibility was just welding a peice of flat stock over the hole where the hitch pin goes now, then drilling a hole through it, ending up with a thicker piece of metal where thehitch pin hole is egging out. I need to look at the rest of this rear bracket to see if it needs reinforcing as well. I wish I had taken a look at the sleeve hitch at Sears (rather than just at the picture). Even though I don't need the raise and lower, it would be interesting to see where/how they attached it to the tractor.
John Mc
   / Sleeve Hitch #12
Here's a few pix of the sleeve hitch on a Murray. It sounds like the Craftsman is pretty similar. The mechanical lift provides quite a bit of leverage to lift attachments. I have a disk harrow and a box blade that use the sleeve hitch. As was mentioned by others it is a nice feature to be able to lift the attachment at the end of a pass. I had a homemade rake that didn't lift and it was useable but it was a real pain. I'm planning on converting it to work with the sleeve hitch so I can lift it.
John
   / Sleeve Hitch #13
Another view with hitch up.
   / Sleeve Hitch #14
A view of how it connects to tractor
   / Sleeve Hitch #15
A view from the top down
   / Sleeve Hitch #16
I have a sleeve hitch on the back of my Murray garden tractor. It provides enough leverage to easily lift the self-powered 36" wide rototiller at the end of rows. This works well when the job is too big for the 20" Troy-Bilt and too small for the 60" Mashio on the back of my tractor. The sleeve hitch provides much more than just a stronger hitch point for hauling a cart. Ron in Central New York
   / Sleeve Hitch
Great pics... thanks... I could probably have something made up like that, but it probably would end up being a whole lot easier to just by the $129 part at Sears.
Thanks again..
You said you have the discs, correct? Do they work OK?
I would use that to turn the soil in the garden that ranges from 5000 to 10000sq ft (maybe more in the future)
Once I tilled the soil this spring it is not too hard... Old farm fields.
Let me know how yours works out..
Thanks
Curtis
   / Sleeve Hitch #18
Curtis,
I have a 14hp Turfmaster tractor made by Western International, Inc with a sleeve hitch on it. This company made tractors and implements under several different names including but not limited to: HOMKO, LAWN SCOUT, AMF,TURFMASTER, and DYNAMARK.
The model number for the hitch is: 5667-0200.
Attached is a picture from the owners manual.
I will place the full implement pages in following messages.
BTW, I don't have any of the implements.
Capt Ron
   / Sleeve Hitch #19
Here's the full accessories page.
   / Sleeve Hitch #20
Page 2.
I'm not sure but Western International, Inc may be out of business.
Just for the record the address is:
P.O. Box 377
Des Moines, Ia. 50302
No telephone number is listed.
Capt Ron
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
More info coming soon! (A53421)
More info coming...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2023 ARMOR LITE TRAILER BELLY DUMP TRAILER (A53843)
2023 ARMOR LITE...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
