Sleeve Hitch
   / Sleeve Hitch #11
<font color=blue>Sounds like I could fabricate something with just a block of metal with a hole through it bolted to the frame. Sound right?</font color=blue>
That's what I was thinking. I haven't yet taken a good look at mine to see where I might attach it. One possibility was just welding a peice of flat stock over the hole where the hitch pin goes now, then drilling a hole through it, ending up with a thicker piece of metal where thehitch pin hole is egging out. I need to look at the rest of this rear bracket to see if it needs reinforcing as well. I wish I had taken a look at the sleeve hitch at Sears (rather than just at the picture). Even though I don't need the raise and lower, it would be interesting to see where/how they attached it to the tractor.
John Mc
   / Sleeve Hitch #12
Here's a few pix of the sleeve hitch on a Murray. It sounds like the Craftsman is pretty similar. The mechanical lift provides quite a bit of leverage to lift attachments. I have a disk harrow and a box blade that use the sleeve hitch. As was mentioned by others it is a nice feature to be able to lift the attachment at the end of a pass. I had a homemade rake that didn't lift and it was useable but it was a real pain. I'm planning on converting it to work with the sleeve hitch so I can lift it.
John
   / Sleeve Hitch #13
Another view with hitch up.
   / Sleeve Hitch #14
A view of how it connects to tractor
   / Sleeve Hitch #15
A view from the top down
   / Sleeve Hitch #16
I have a sleeve hitch on the back of my Murray garden tractor. It provides enough leverage to easily lift the self-powered 36" wide rototiller at the end of rows. This works well when the job is too big for the 20" Troy-Bilt and too small for the 60" Mashio on the back of my tractor. The sleeve hitch provides much more than just a stronger hitch point for hauling a cart. Ron in Central New York
   / Sleeve Hitch
Great pics... thanks... I could probably have something made up like that, but it probably would end up being a whole lot easier to just by the $129 part at Sears.
Thanks again..
You said you have the discs, correct? Do they work OK?
I would use that to turn the soil in the garden that ranges from 5000 to 10000sq ft (maybe more in the future)
Once I tilled the soil this spring it is not too hard... Old farm fields.
Let me know how yours works out..
Thanks
Curtis
   / Sleeve Hitch #18
Curtis,
I have a 14hp Turfmaster tractor made by Western International, Inc with a sleeve hitch on it. This company made tractors and implements under several different names including but not limited to: HOMKO, LAWN SCOUT, AMF,TURFMASTER, and DYNAMARK.
The model number for the hitch is: 5667-0200.
Attached is a picture from the owners manual.
I will place the full implement pages in following messages.
BTW, I don't have any of the implements.
Capt Ron
   / Sleeve Hitch #19
Here's the full accessories page.
   / Sleeve Hitch #20
Page 2.
I'm not sure but Western International, Inc may be out of business.
Just for the record the address is:
P.O. Box 377
Des Moines, Ia. 50302
No telephone number is listed.
Capt Ron
John Dozer JD650 (A51691)
John Dozer JD650...
1472 (A51247)
1472 (A51247)
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
