Slip Clutch Question
   / Slip Clutch Question #1
RobT
Bronze Member
Centerville, IN
Rural King Foton 404
Hello.
I have a 5' rotary cutter with a 40HP tractor and have gone through about 10 shear bolts in the 15 hours or so I've used the cutter. I want to invest in a slip clutch, but have some questions that I hope some of you can help me out on:
1. Do I buy a slip clutch for each PTO-type implement I have? That is, do I need one for the rotary cutter, one for the rototiller, etc.?
2. Are there any disadvantages of a slip clutch (other than the cost, but I'm willing to buy one now)?
Thank you for your help!
RobT
   / Slip Clutch Question #2
1. Yes, you will need one for each implement. The clutch goes between the implement gearbox and the PTO shaft.
2. The only disadvantage that I can see is the yearly loosing up of the bolts to slip the clutch before you can use it.
   / Slip Clutch Question #3
If that many shear bolts, I'd look at what I was cutting and why the bolts were shearing. It doesn't sound like it is the type of cutting the cutter was really designed for. What is doing it -- large stems, rocks, dirt, speed, ???
   / Slip Clutch Question #4
When I read <font color="blue"> dirt </font> I had to laugh. You are right that is one of the problems a lot of the time. I don't think that there is anything that will shear a pin any quicker that scalping the ground.
beenthere:
You are exactly right. I went through most of them because of my ignorance--starting off in high RPM, stopping and starting too much, not clearing the ground before cutting (I hit some decent size limbs), and not having the cutter aligned properly. My bad!
I now am now mowing with more caution and "smarts", or trying to at least. I appreciate the help.
robt
JerryG:
Thank you for the information. For some reason, I trust asking you guys about tractors more than I do sales people. You guys give me the real scoop about stuff.
Thank you!
RobT
   / Slip Clutch Question #7
Slip clutch equipped PTO shafts are expensive, especially if you're buying more than one. You can however, buy just the clutch portion - and retrofit your existing PTO shaft(s).
But 40hp is a lot for a five footer, I had one behind my 21 hp (PTO) horsepower Jinma - didn't need a slip clutch. But when I bought a 40hp (PTO) KAMA, I had to up to a six foot slip clutch equipped IM-602.
//greg//
   / Slip Clutch Question #8
If you want a new PTO shaft with slip clutch, this may do it for you.
PTO shaft
Price is 80 bucks. They have others too.
jb
   / Slip Clutch Question #9
OK, it's been determined a slip clutch can be added to any implement but how would one ensure proper tension?
What I mean is how do you size the clutch to a specific tractor. It would seem to me that not all slip clutches have the same tension and not all tractors are manufactured with the same size materials.
Are they rated by PTO HP or is ther another spec I should look at to size a slip clutch PTO shaft? My new chipper is a direct connection sans shear bolt or slip clutch, has me a bit concerned. The belt drive would seem to be the weak link but with five belts /forums/images/graemlins/blush.gif...That's a pretty stout connection.
   / Slip Clutch Question #10
</font><font color="blue" class="small">( The only disadvantage that I can see is the yearly loosing up of the bolts to slip the clutch before you can use it.
)</font>I took a piece of aluminum bar stock and milled up a thickness guage. When using it, I minimize the pressure and movement so as not to wear the guage.
   / Slip Clutch Question #11
Take a look at Highbeam's method on the post below. I haven't tried it yet, but from my limited experience with a slip clutch it sounds good. I ran a bush hog with an over run clutch for 5 years on the original shear pin then traded tractors and broke 5 pins the first day, all from fast starts with the electric pto engagement.
pre-season adjustment
   / Slip Clutch Question #12
</font><font color="blue" class="small">( OK, it's been determined a slip clutch can be added to any implement but how would one ensure proper tension?...
)</font>
Dead simple, and the instructions should come WITH the slip clutch. Adjustable springs maintain contact between the friction plates. You simple use a ruler or calipers to adjust the spring length to provide the ft-lbs of torque required to counter the specific PTO horsepower of any given tractor within it's range. They can typically be adjusted within the 20 to 50 PTO horsepower band.
//greg//
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
UNUSED SDLANCH SDLD25 MOBILE HYD DUMPER (A60430)
UNUSED SDLANCH...
