small engine synthetics
   / small engine synthetics #11
</font><font color="blue" class="small">( I changed to synthetic oil in all my small engines FIRST, because they're the ones that'll benefit most because they're air cooled and likely run a bit hotter than water-cooled. Synthetics can stand higher heat without breaking down.
Now, I've synthetic in all my engines and have even put synthetic power steering oil in a couple of the vehicles.
Ralph )</font>
Ditto to all that for us too! /forums/images/graemlins/grin.gif
Plus synthetic brake fluid is way better as well.
   / small engine synthetics #12
I don't quite remember the manufacturer, it was not B&S, the other major one, used in snowblowers. I was doing the resume of this gentleman and I questioned him again and again but he was insistant.
Mike
   / small engine synthetics #13
</font><font color="blue" class="small">( I don't quite remember the manufacturer, it was not B&S, the other major one, used in snowblowers. I was doing the resume of this gentleman and I questioned him again and again but he was insistant.
Mike )</font>
Kohler perhaps? My generator came with a Wisconsin Robin/Subaru and I dought thats who you talked to. No biggie... I was just curious.
   / small engine synthetics #14
Probably Tecumseh.
   / small engine synthetics #15
Briggs and stratton say to use 10w30 synthetic or single grade dino. 30w dino for temperatures above some temperature I won't work below and some other grade below that. They say NOT to use dino multi-grade oil.
I use mobil 1 10w30 in my air cooled engines. Maybe not the best oil in the world but I am only 1/3 through the case I bought at costco a half a decade ago.
   / small engine synthetics #16
</font><font color="blueclass=small">( Had a serious several conversations with factory rep for small engines 10 years ago, said don't use synthetics, their tests showed their engines ran hotter on them. )</font>
I deal with many reps day in day out in the auto industry. I am not here to prove you or him wrong but it’s amazing on how many reps are not educated in the field they per cure. A lot of reps today are pre programmed on what to tell you. Actually I don’t even consider them reps but rather corporate salesman. Running synthetic does not make your engine run hotter. I don’t have proof of this just common sense /forums/images/graemlins/cool.gif
Less friction=less heat
   / small engine synthetics #17
I have a 52" mower with a B/S 20hp motor in it that I've had for perhaps seven years. I just put Royal Purple 30W in it, used it hard to mow a few acres that were wildly overgrown, and just last night I heard it start knocking. /forums/images/graemlins/frown.gif Hmmm...I wonder if the Royal Purple loosened enough crud to put the filter into full bypass? I only let it knock/rattle for a total of maybe five seconds. Plans are to put a fresh filter on it along with a Royal Purple refill. We'll see, but I am not presently terribly happy with my choice to switch to synthetic on that particular machine (though have had issues like this with synthethic conversions before).
   / small engine synthetics #18
   / small engine synthetics #19
</font><font color="blue" class="small">( Hi all. The search function doesn't work this AM, so this may be covered elsewhere. What does everyone think about using synthetics motor oil in, say, a wood splitter? Mine is an 8 hp Briggs horizontal that runs at full governed RPM with variable, sometimes heavy, load. I'm thinking of the benefit of easy starting (recoil) mostly. I change oil yearly, after maybe 40 hours operation. Engine is in good shape. Thanks, Jim )</font>
I have 3 different "smaller" gasoline engines here at home..and was told ( and didnt belive it) that running MULTI WEIGHT oil in them would increase oil CONSUMPTION....and in 2 Kohler's and 1 B&S...its a FACT. STRAIGHT 30W in them runs fine..very , very low consumption. I switch to 10W-30...and oil consumption triples! But...if ya check the oil all the time...its no big deal. Not like 30W uses a ounce per hours and multi weight ues a allon or anything.
I DOUBT SERIOUSLY if switching to a SYN oil is going to affect easier starting..one way or the other! My 8 HP Kohler on a rear tine tiller..is a definate "MUTHA" to pull start any time of the year....MAN has it got some compression... /forums/images/graemlins/grin.gif
   / small engine synthetics #20
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
2003 McCormick XTX 185 XtraSpeed Tractor (A55218)
2003 McCormick XTX...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
Estate Equipment Auction 9/27/2025
Estate Equipment...
