snow blower use questions
   / snow blower use questions #11
as mentioned by others a rear pull combined with your existing v plow could be a great combination. . As far as speed with my 74" prononvost i would imagine that i could go 3-4 mph with 6-10 inches of dry snow (jd 3720 35 pto hp claimed)- I know that at 4 inches of dry i can just go full speed B range-7 mph.
The downsides to a rear pull are pretty well known- deep drifts could be a problem though that size tractor should be able to get through several feet of snow. Too, any blower requires care on a gravel road. Pronovost has a kit that replaces the hydraulic
rear blade with a set of wheels - might be great for early or late season- i tried to link to it but all Pronovost sites give me a 403 error today
I wonder why you are breaking shearpins and having so many chain issues, typically dual auger machines are intended for and built for severe service. They also tend to use a good bit more power than a single auger thus slowing things down a bit. I think its very possible/likely that some blowers are a good bit more efficient than others. I know when i replaced my kubota with frt blower (about 4.6 hp per ft of blower) with my current set up (about 5.8 hp per ft) that instead of being able to go 25 or 30% faster on a given snowfall i was able to go at least double. Too, the control given by the commercial chutes is great especially in constricted areas or near buildings. I have a couple of dangerous sections along my drive and previously i would build berms with a blade to help keep vehicles on in case of sliding, now i use the blower to build higher and thicker berm than i could with a blade.
How wide is your road? that might change the best clearing strategy. Maybe as suggested you should plow to the center then blow from there or blow every few storms depending on the shoulder available and type of snow.
I plow a lot. I keep close to 2 mi open on my place and do about 25 driveways & lots. All but 2 are dirt.
My current method is with a frame mounted Fisher "EZ-Vee" 9'6" blade. When the banks get too big to push back or I just run out of room (woods), I'll get out the blower (8' dual auger Loftness) and the customer get's charged for that. That makes ALL my blowing what I would estimate to be "severe", meaning very deep and usually hard & icy snow. Shear bolts and chain repair is common & frequent.
My reasoning (and question) is simply speed. Normal snows are 6-10" and it's hard to beat the speed of a blade, but with that said, I've never blown a "normal" snow either. My tractor is borderline under powered for that blower (80 ish pto hp) for much over 16". I'm wondering what travel speed would be reasonable for the blower in a "normal" 6-10" fresh snow? It's usually a fairly dry nice snow. I have been considering making a front mount for the blower for comfort & convenience but I question myself how often I would use the blower over the blade. In the past it's also handy to have both on for a final clean up.
Funny, after posting this I noticed you have a wing on your wish list per another thread. Old plow blades are pretty cheap in the summer. Make it happen. :D
I'm getting closer:thumbsup: Found this "underbody" blade the state roads dept. brought to the scrap yard for $375. It's 10' long and the moldboard is 3/4" thick. If you've never seen one, this pic is difficult to understand as they "fold" flat for transport clearance. I am hoping to make a very heavy duty rear blade capable of swinging off to the side to give me 3 or 4 feet of winging action. Not that great but it will do for my use and as heavy as it is, will make a nice rear (dirt) blade as well.
I believe my shear pin/chain problems are from my use blowing back old & icy snow banks, often so hard that I can't push the blower into it in 2wd.
You can see in the top pic that the chain was exposed on the rt side, the side I always look back at from years of haying & bush hogging. I built a guard last year and that did help. (below)
The roads on my place are mostly about 16-18' wide, then there are smaller single path that are old skidder trails. These are a little rugged for the blower and I don't bother keeping them in as nice condition as the "main" roads. (I cut fire wood in the winter) All the roads are in the woods and subject to fallen sticks/limbs under the snow. I don't think there's a "magic bullet" remedy, and to be truthful, it's all fun to me anyway.:D
   / snow blower use questions #15
That blade looks like a beast. Grader blade? The mount looks to have a huge amount of heft. So you are thinking back blade instead of wing? I really like the wing idea. :) You may want to add some rubber to the top of that blade like on your front blade. I have it on my truck's plow blade and it helps bigly. :D
Yeah, Iirc it was 776 pounds as it sit's in the pic.!
I'd love a wing but I'm not completely sure how I'll use it yet, it's out back half buried in the snow, A true wing (like) build will be rather complicated and I have concerns about building supports with enough heft to carry it without breaking them or damaging the tractor.
You missed the rubber on the plow, it's there.:thumbsup: I want to find a Fisher XV-2 for the tractor :licking:
   / snow blower use questions #19
The belly scrapers mount under the center of the plow trucks of coarse to the frame, and the driver puts down pressure onto the road to scrape off the hard pack.
   / snow blower use questions #20
that chain looks a bit small in that pic- and surprisingly exposed
i wonder if some teeth on those augers would help break up the ice a little better- maybe you could have some short rectangular sections welded on
man your roads are nice and wide- to me thats an additional good argument for a blower to get the snow out of there
what are the individual drives like?- easy push's?
QUOTE=Rustyiron;4971260]I believe my shear pin/chain problems are from my use blowing back old & icy snow banks, often so hard that I can't push the blower into it in 2wd.
The roads on my place are mostly about 16-18' wide, then there are smaller single path that are old skidder trails. These are a little rugged for the blower and I don't bother keeping them in as nice condition as the "main" roads. (I cut fire wood in the winter) All the roads are in the woods and subject to fallen sticks/limbs under the snow. I don't think there's a "magic bullet" remedy, and to be truthful, it's all fun to me anyway.:D[/QUOTE]
Giyi Mini Pallet Forks (A57149)
Giyi Mini Pallet...
LOT: (2) Komatsu Part # 207-70-73210, (2) Komatsu Part # 208-70-73220 (A59076)
LOT: (2) Komatsu...
Katolight SED60FJJ4 60kW Towable Diesel Generator (A56857)
Katolight...
TPM 10 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
TPM 10 Piece Mini...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
Misc Pallet of Toolboxes with Lights and Power Tools (A57454)
Misc Pallet of...
