Snow Plow Cylinders With Rust On Piston Rods
   / Snow Plow Cylinders With Rust On Piston Rods #31
These single acting snowplow cylinders are more commonly known as "Ram" cylinders and most of them, if not all of them, seal on the rod. There is no piston and the differential pressure area is the rod diameter itself. The inside end of the rod has a guide ring either secured with a nut or else it's a split ring in a groove. The purpose of this ring is only for guiding the rod and not for sealing.
The outer end of the cylinder, where the rod comes out, has one rod seal as well as a separate wiper. Rod seals are either a single V-ring or U- type seal or else a series of "Chevron" seals depending on the manufacturer.
Any high spots or defects on the rod are passing right across the only seal.
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A52706)
UNUSED FUTURE MINI...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2018 FREIGHTLINER...
GODWIN 6 HEAD PUMP (A55745)
GODWIN 6 HEAD PUMP...
2005 Mitsubishi Lancer ES Sedan (A55853)
2005 Mitsubishi...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
Aluminum Can Trailer (A54865)
Aluminum Can...
