Oil & Fuel So Valvoline produces ALL of Kubota lubricants...
   / So Valvoline produces ALL of Kubota lubricants... #11
OK - just so I can get this straight and learn something here - are you using this like you would use a Tractor/Hydraulic Fluid in a common reservoir for both transmission (geared from your comment) and hydraulics or does your equipment have separate tanks for the transmission and hydraulics and this for hydraulics only ?? Thanks
gg
   / So Valvoline produces ALL of Kubota lubricants... #12
gg
Very few modern tractors separate tranny fluid from hydraulic fluid & no CUTs I'm aware of. I'm aware of some backhoes that had separate sumps at one point.
Some heavy equipment, I want to say some Cat skidsteers, maybe backhoes or something actually specified using engine oil in their hydraulic system rather than a hydraulic oil. So in some cases fluid choice is less critical than people worry over. I have a HST machine & those tend to be a lot more sensitive to fluid type. So I stick with the OEM SUDT2, especially as I plow snow with mine & also run it in 100 degree temps.
My only point of differentiation in the whole scheme of things is the front axles of my FWA tractors, they both get 85-90 GL5 gear oil.
   / So Valvoline produces ALL of Kubota lubricants... #14
Man I am sorry but I guess I am really slow because I can't find a straight answer to my question. Do I hear you guys saying that using Hydraulic Oil in a tractor transmission instead of Oil speciallyn formulated for wet brakes and heavy gear pressure is fine ????
gg
   / So Valvoline produces ALL of Kubota lubricants... #15
It's my contention that the only time hydraulic fluids become really critical is in a Hydrostat drive. If I was running a hydrostat anyhting, I'd use the OEM specified fluid, whatever that would be. The only exception would be no 303 spec fluid in anything. 303 series fluids are obsolete and contain no seal preservatives or anti wear additives. Obsolete but places like TSC still sell them. TSC branded cheap fluid is 303 series. You get what you pay for.
Hydraulic oil specs become important in systems with wet clutches and wet brakes. Friction modifiers and compatibility with organic and inorganic linings become very important very quickly.
   / So Valvoline produces ALL of Kubota lubricants... #16
gg
That would depend on the tractor. An old machine with dry brakes & clutch obviously doesnt have that compatibility issue. Heck poor quality modern fluid will be better that top shelf oils of a few decades back. A modern machine with wet brakes or clutch requires a fluid designed for those clutch/brake pads. The always applicable rule: follow what's listed in the owners manual. There may be better options, but stuff meeting or exceeding OEM specs will get you to the expected lifespan of the machine most of the time.
   / So Valvoline produces ALL of Kubota lubricants... #17
I did some research right after i bought my BX. NO other brand cites compatibility with Kubota hydrostats. I found then that Valvoline was their contracted supplier. They will not discuss the product or their relationship with Kubota except one sorta candid guy said they cannot discuss proprietary contract branding arrangements but that there is not much difference. I use a NAPA product that does have compliance with Kubota UDT. Over time (1500 hours) I have not been able to detect any difference in performance or the whine others describe. I have used SUDT@ a couple times as a test to determine that.
Ron
Ron
My philosophy exactly. I use either Chevron All weather THC Synthetic or Rotella AW 42 depending on availability. Both are Kubota certified substitutes (states that right on the pail). At 3500 and 2200 hours respectively on each tractor, I'd say my fluid choices are just fine.
   / So Valvoline produces ALL of Kubota lubricants... #19
I hope you mean that Chevron and Shell are certifying the oils are substitutes for Kubota oils. Because it doesn’t really read that way and Kubota certainly isn’t endorsing competitive oils.
   / So Valvoline produces ALL of Kubota lubricants... #20
UNUSED FUTURE 72PRO 72" HYD MULCHER (A58376)
UNUSED FUTURE...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
Utility Cart (A59228)
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2005 Hyundai Semi Trailer (A57148)
2005 Hyundai Semi...
UNUSED JCT 84" SNOW PUSHER (A58376)
UNUSED JCT 84"...
