3RRL (Rob):
I have been following this thread for sometime now and enjoy it. I guess I missed the post where it said your Onan PULLED air in the radiator vs. PUSHING is out. Is this for sure? I would have predicted it is a "pusher".
I have a weekend offgrid place and installed an 8KW diesel in an insulated "doghouse" (enclosure) on a slab inside a shed for noise treatment reasons as much as anything. Diesels aren't the quietest things around! The direction of airflow is in via fresh air louver to the generator end past the engine and OUT the radiator/2x louvers.
I ended up having to fab a shroud to duct radiator hot air to the louvers at side of shed. Later, I discovered the shroud itself was rejecting so much heat (in summer which is when it gets the most use: think A/C) that I had to insulate the shroud as well as add a large box fan in front of the air inlet louver to force as much of the heat out of the shed as I could (fan is wired/fused to genset outlet so it only runs when genset is running.)
RavensRoost
