Split-dovetail car hauler trailer
   / Split-dovetail car hauler trailer
I cut out the opening for the main light (its going to have 3 different lights) with my jigsaw, its not perfect but you won't be able to tell once the light is mounted.
Main light sitting in place.
Light lit-up, what'd ya think I was gonna use those hemostats for?
Tongue and hitch, this was a pain getting everything lined up. I used a 12,500lb Bulldog hitch and 6" channel for the tongue.
Helper with her shoes on the right feet.
I measured and ordered two straight 5200lb axles (with brakes on both) from a local trailer dealer, when they came in they were 6000lb, he let me have them for the same price. I welded the hangers on with the trailer upside down then flipped it over and bolted on the axles.
Trailer is skinned. I used 14 gauge diamond plate for the decking. I used five 4x8 sheets. The cuts were made with both a cut-off wheel and my jigsaw. I used a whole tank of shielding gas welding the plate on. I used 1/2" metal for spacers on the cross members to level the plate to the outside frame.
Front bar (for lack of a better name) made and welded on. I capped the ends the same way I did the ramps.
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
Breaker Box (A57454)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
Brent 320 Auger Wagon (A59814)
Brent 320 Auger...
John Deere HD300 Sprayer Utility Cart Attachment (A56857)
John Deere HD300...
