Split-dovetail car hauler trailer
   / Split-dovetail car hauler trailer
I've been working on some attachments for the hitch. Here's what I came up with for a winch cable roller
A brace for another attachment. Can you see where i'm going with this one?
   / Split-dovetail car hauler trailer #95
I have seen trailers that mount a swivel implement jack on each back corner. Swivels horizontal when not in use.
A rack for the Bud Light?
Funny you should mention that...it's in the works, not Bud Light but we'll see what I can come up with.
That's a good idea, I just hate the way they look on the back of a trailer.
Here it is bolted between the dovetail. I used four grade 8 bolts, bolted in from the bottom. I also made the pins in my lathe (pin in the winch roller also) I turned them down from bigger grade 8 bolts and drilled them with a drill press.
When not is use (most or probably all of the time) it stores out of the way under the front part of the trailer.
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A52709)
2016 CATERPILLAR...
2021 FORD F-350 (A58214)
2021 FORD F-350...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
Bench Grinder (A57454)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Mini Excavator  Quick Coupler (A57149)
Mini Excavator...
