Splitter
   / Splitter #11
One more thing Scotty,,,,, I wish you'd change that Avatar, makes me cold!!!! ;)
   / Splitter #12
ovrszd said:
What????? It's not already Farmall Red Scotty????? I am shocked!!!:eek:
Afternoon Ovrszd,
Nope its HD Orange :(
BTW the snow scene should keep you nice and cool now ;)
   / Splitter
I have the gas engine ready to mount and the pump should be delivered today. I put the oil filter adapter on along with the filter. I'll be taking and sending some pictures soon.
Joe
   / Splitter
The engine is mounted now. The pump has been delivered.
QUICK QUESTION??? When a pump turns clockwise to work, is that looking from the spindle end or the opposite end?
Thanks.
Joe
P.S. There are no markings on the case indicating direction.
   / Splitter
The splitter is complete and works. I used a 5 gallon, thick plastic container for the reservoir. It does get air in it...I think adding more fluid would help.
I will be posting pictures soon, and disassembling for paint.
Thanks for all your help with this guys.
Joe
   / Splitter #16
Joe,
Good work. The air may just be from the cylinder. Did you extend and hold then retract and hold a few times? That's needed to purge the air out.
By the way, My Ford tractor has a 23 gpm pump and a 5 gal reservoir from the factory. You'll be fine.
Uh, you do have a pressure relief in the system - right?
jb
   / Splitter
The pics are here. I've since changed the fuel tank and, umm, tires/wheels since these pictures. LOL:D I'll get some new shots soon.
Joe
   / Splitter #18
I can't understand why you would want to change the tires. :rolleyes: You should have turned the white letters out, though. What kind are they? B. F. Woodrich.......:D :D
   / Splitter #20
joewilshire said:
I've seen splitters that use the frame/housing as a tank. Any ideas about this?
Thanks.
Joe
Yes, build the frame to hold the hydraulic fluid, it will dissipate the heat better than a plastic tank. I would recommend a 2 stage pump also.
2017 Ford Fusion Hybrid Sedan (A55758)
2017 Ford Fusion...
2014 Toro Greensmaster Flex 2100 Towable Walk-Behind Reel Mower (A55787)
2014 Toro...
Kubita RTV1100 (RUNS) (A50775)
Kubita RTV1100...
2009 Pierce 105ft. Quint Ladder T/A Fire Truck (A55788)
2009 Pierce 105ft...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
