Splitter
   / Splitter #11
One more thing Scotty,,,,, I wish you'd change that Avatar, makes me cold!!!! ;)
   / Splitter #12
ovrszd said:
What????? It's not already Farmall Red Scotty????? I am shocked!!!:eek:
Afternoon Ovrszd,
Nope its HD Orange :(
BTW the snow scene should keep you nice and cool now ;)
   / Splitter
I have the gas engine ready to mount and the pump should be delivered today. I put the oil filter adapter on along with the filter. I'll be taking and sending some pictures soon.
Joe
   / Splitter
The engine is mounted now. The pump has been delivered.
QUICK QUESTION??? When a pump turns clockwise to work, is that looking from the spindle end or the opposite end?
Thanks.
Joe
P.S. There are no markings on the case indicating direction.
   / Splitter
The splitter is complete and works. I used a 5 gallon, thick plastic container for the reservoir. It does get air in it...I think adding more fluid would help.
I will be posting pictures soon, and disassembling for paint.
Thanks for all your help with this guys.
Joe
   / Splitter #16
Joe,
Good work. The air may just be from the cylinder. Did you extend and hold then retract and hold a few times? That's needed to purge the air out.
By the way, My Ford tractor has a 23 gpm pump and a 5 gal reservoir from the factory. You'll be fine.
Uh, you do have a pressure relief in the system - right?
jb
   / Splitter
The pics are here. I've since changed the fuel tank and, umm, tires/wheels since these pictures. LOL:D I'll get some new shots soon.
Joe
   / Splitter #18
I can't understand why you would want to change the tires. :rolleyes: You should have turned the white letters out, though. What kind are they? B. F. Woodrich.......:D :D
   / Splitter #20
joewilshire said:
I've seen splitters that use the frame/housing as a tank. Any ideas about this?
Thanks.
Joe
Yes, build the frame to hold the hydraulic fluid, it will dissipate the heat better than a plastic tank. I would recommend a 2 stage pump also.
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A55788)
2014 Dodge Ram...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
2014 Ram 1500 Crew Cab Pickup Truck (A55788)
2014 Ram 1500 Crew...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
