Splitting a TC24DA
   / Splitting a TC24DA
I'm not exactly thrilled having to do it, but I really don't have much choice. The last thing I ever expected was a problem like this.
I wouldn't be surprised if the dealer knew it was leaking before they delivered it...and I have reason to believe they did.
I sent you a PM
The 2 hr ride(one way) is for the dealer I bought the 21 from, 5 yrs ago. I traded the 21 in for 24 at a local dealer, about 30 mins away.
After all I've been through with these people, I will not give them a chance to burn me again. Trust me, if I thought I could trust them, I'd let them do it.
edited to say...I did consider the dealer I bought the 21 from, but decided against it. One reason...I didn't buy it there.
   / Splitting a TC24DA #13
I would call the dealer you bought the 21 from. Explain to him that because of the distance traveling when you traded you bought from one only 30 minutes away. Then tell him that after the sale now it was a mistake. Tell him you wished you would have bought from him and am wondering now if he is interested in handling the warranty work. He might just say he understands the traveling deal and would be glad to help you out. You never know.
murph
   / Splitting a TC24DA #14
To add to Murph's suggestions fire a letter off to New Holland and let them know which dealer you would like to take your tractor to for service. I'm sure they will pave the road for your trip, they don't want to lose a customer. PM me for NH's address.
   / Splitting a TC24DA #15
Use dye if you wish; this is not a high tech problem, though. The oil is either motor oil from the rear seal, or hydraulic oil. You say it is hydraulic oil, so it is more than likely coming from the transmission input shaft seal. After splitting the tractor, it will be apparent to any competent troubleshooter where the leak is, dye or no.
   / Splitting a TC24DA #16
<font color="blue">Maybe someone here can refer me to a reputable and honest dealer in CT...anyone???</font>
Not sure what part of CT you are in, but I can recommend Dealers in So. NH and So. Maine. Personally I'd rather spend two full days dropping off & picking up the tractor than having it in pieces in my garage.
Do you have the repair manual? It gives detailed instructions on how to split the machine. You can get a copy here www.newhollandtechpubs.com. I think they run $150-$200 (Gas money for your long trip...)
   / Splitting a TC24DA #17
"The source of the leak is the weep/vent hole"
Fluid level too high?
I've seen a Boomer split in half at the dealership.. it looked like a puzzle w/ 1001 pieces.
I'd try and give the local dealer another shot.. if not the next closest.. at least your warrenty/liability issues will be intact w/ a NH dealership doing the work. Sorry about the problems!
I want to thank all of you for your input. I probably should heed your warnings. However I'm having a tough time seeing how letting another dealer perform the repairs, would be in my best interests. Maybe I'm just 'gun shy' over what has already happened. Granted, I'll probably lose my warranty if I do the repair myself...but what kinda warranty do I really have, given the circumstances?
The way I see it, here are my options...
--Bring it either to another dealer in CT or the dealer I bought my 21 from. Either way, it will cost me $300-$400+ for them to transport.
--Borrow a trailer and bring it myself. I'll have to miss time from work for both trips and including fuel, that will cost me a few $$$. If I just use a days pay(1/2 day bring it 1/2 day pick up) and the fuel...it's real close to what I would pay for them to haul it.
--Do it myself and have the satisfaction of knowing what specifically was leaking and correcting the problem. By no means am I implying any discredit to any NH techs, but by being employed at GM dealers for almost 30 yrs, I know what it's like to be on both sides of the fence. Splitting a new tractor with 8 hrs on it is no different than splitting a new Caddy with 8 miles on it. It takes a certain finesse that many dealers(Not All!) just don't posses. But that's another topic and I'll just leave it alone.
I still believe NH builds a quality product, and with that said, I would hope the 24 follows the same path as the 21 did....I never had to bring it to a dealer in the 5 yrs I had it(at least not until the inj pump issue). That is my basis for wanting to repair it myself. If this tractor is going to cost me $300-400 for every warranty issue...keep the warranty!! I'm sure some of you will say something about a 'catastrophic failure' like an engine, trans, axle, etc that could cost $$$$ just for the part alone. You'd have a valid point too! On the other hand, I'm a pure optimist and tend to think positive for even the worst case scenerio.
Your right, fluid leaks are not a high tech problem, and neither are tractors. But suppose this leak is a porous case problem? You don't expect me to believe that isn't a possibility do you? A leak from day one... and only 2 hrs... could very well be a porous case, bad seal or 'O' rings, or even loose hardware. Using dye is just cheap insurance to prove the leak location.
Yes it is hydraulic oil and not engine oil
I know the difference /forums/images/graemlins/smirk.gif
<font color="blue"> Dealers in So. NH </font>
Let me guess...Chappell
Good people and good place! That's where my 21 came from and the 24 SHOULD have as well!
I still have the manuals for the 21 and there are a lot of similarities, but not exact. The full set for the 24 is on backorder...or at least that's what I've found.
JOHN DEERE LOADER LINKAGE (A52708)
JOHN DEERE LOADER...
3PT CARRY ALL (A58374)
2014 KOMATSU D51PXi-22 CRAWLER DOZER (A52709)
2014 KOMATSU...
2015 MACK CXU613 (A58214)
2015 MACK CXU613...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52708)
KNOW BEFORE YOU...
LOT: (9) Sets of Gutter Broom, 250 KP, Std 26 (5 SEG) (A59076)
LOT: (9) Sets of...
