Sprayer?
/ Sprayer? #1
tower59
Texas
Have about three quarters of a mile worth of fence line I need to spray with Roundup to keep clean, and also may have as much 3-5 acres of land I may want to spray in the future with fertilizer and/or weed killer to develop a nice grass pasture. I have never had a sprayer before. Would I need a sprayer that sprays off to one side so that I could just ride along the fence line to spray, and one that could also spray a wide path behind to get the fields? What specific sprayer would you recommend? I could use a tractor or a Mule to do this job. Thanks!
/ Sprayer? #2
I built my own boom with 4 spray heads, with valves between each so I could spray with any single spray nozzle or all 4. I built it to spray along rows of trees, and to spray along fence lines. I also use it for herbicide and for fertilizer.
I mounted it on my garden tractor on the front weight bar. Pull a 30 gal. nurse tank with a 12 v Shurflo pump. Works great. There are several commercial ones that would do the same (may have to add the shut-off valves between the spray heads).
/ Sprayer? #3
You can buy 25 gallon towable sprayers or tanks that mount to you 4 wheeler that are a little smaller, say 15 gallons. These can come with a 3-4 foot spray width boom and also have a wand that can be used for spot application or just held inhand for application to a fence row as you slowly drive down it.
/ Sprayer? #4
As Clemsonfor suggested, there are tanks for ATV's or garden tractors that can be towed or mounted on an ATV, depending on which one you choose. After we moved to where we are now, I borrowed a tow behind version, I think 15 gal., from the neighbor and it worked pretty well for broad leaf weed control applications. I towed it behind my garden tractor. It had a self contained electric pump and its own 12 volt battery. After I got a compact tractor, I bought a 55 gallon version and a PTO pump. It is "boomless" and you can set the nozzles to spray just one side or any combination. Below is a link to an similar ATV version.
25 GALLON LAWN & GARDEN/ATV BOOMLESS SPRAYER LG-3025
I recently purchased a 15 gallon spot sprayer just to use with round-up type products. It only has the spot sprayer, not a boom, but I did not think it was that likely I would want to kill really large areas. I just sit it in my bucket with a trolling motor battery and drive down the fence line spraying or I can park and spray if I have an area I want to hit a little harder. It really worked well and I spent less than $100 for it.
Spot Sprayer, 15 gal. - 2138134 | Tractor Supply Company
/ Sprayer? #5
I did not notice you mentioned that you had a tractor. Below is the one I bought for the tractor. You have to add a PTO pump and a coupling and it does not come with the spot spray wand. I added it too. For my purposes which is spraying weed control or weed & feed 2 or 3 times a year it works fine. I am also not concerned about pin point application for a garden or crops. But with the boomless, you probably have to be more concerned with wind conditions. On the other hand I don't have to worry about catching the boom on a tree in the yard. I think the Fimco products fall into the basic level. I'm sure there are higher end products for commercial users.
55 GALLON 3 PT SPRAYER - Agri Supply
/ Sprayer?
Thanks for your responses! In choosing the right size sprayer, I'll need to figure out how many gallons it will take to spray just the fence line- what is your experience here? How many gallons to get .75 mile of fence? Thanks!
/ Sprayer? #7
have no idea but it goes a long way, i sprayed 30 gallons out of my friends spot sprayer (15 gals) and i hit every sweetgum and persimmion that had popped up in my field that i am trying to reclaim, as there were several, multi years that it did not get cut. and it was a lot and i soaked all of them good.
/ Sprayer? #8
I could do that with my 30 gal sprayer, even using all four spray heads on with 12 psi pressure.
/ Sprayer? #9
The 12v pumps on the 15 gal spot sprayers burn up pretty fast when you start using them for continuous duty like boom spraying a couple of acres. Don't ask how I know ;)
When spraying acreage you will want something that has good capacity and a big enough pump to handle a wide boom/swath. Less filling up and less passes.
How many gallons you need to spray a .75 mile fence will depend on how heavy and how wide you are putting it down. If you are just going for right under the fence about 12" wide I think you could possibly get it done with a 15 gallon sprayer.
You might look at getting a 15 gallon for spraying the fence and spot spraying and then something more heavy duty when you are ready to start spraying the field.
/ Sprayer? #10
Blue 55 g drum with a shur flo pump and a coily garden hose. Car battery.
Generic roundup is about $40 for 5 gallons. One of those in the drum takes care of just about anything.
/ Sprayer? #11
charlz
My 12v pump has been working fine for going on 16 years now. Pump an average of 500 gal of spray a year (at least 2 if not three times a year on 10 acres of lawn). It does have a return line and I only run 12-15 psi pressure in four spray heads (have a spot wand too). Maybe I'm just lucky, but this Shurflo pump sure doesn't owe me anything.
Sorry to hear yours burned up fast. Hope that isn't the norm.
/ Sprayer? #12
Can you post a link as to where I can buy this 5 gallons of generic roundup for $40?
Thanks:confused:
/ Sprayer? #13
I fill my sprayer to 14 gallons (+/-) and use about half of the tank using four nozzles to spray the "right" side my driveway (6' wide) then turn around and use the rest to go the other direction. Which works out to be about 14 gallons per acre.
I have the pressure set pretty low (20psi??) and drive about 2.5 - 3 mph in Med. range - which might be fast for the woods... I built my first sprayer with an electric pump... forgot to drain it, so it froze and cracked. Have a pto pump now and it's (maybe) too big for the job.
/ Sprayer? #14
Thanks:confused:
Oops, my math was a little off. It's $32.99 for a 2.5 gallon container from Rural King. That's who I got it from last time. I got two jugs, so I thought the 32.99 was for the 5 gallons. Oh well. Anyway Rural King also has a 15 gallon barrel for 165 clams. That's a pretty good deal.
Drexel Imitator Plus Glyphosate 2.5 Gallon Jug w/ 15% Surfactant America's Farm & Home Store
If you buy 2 they knock off another 4 bucks. I would check your local suppliers first, as shipping can be expensive. Patent on Roundup ran out several years ago, thus the generics.
/ Sprayer? #15
teg, how long is your driveway? I did the math, but it came out to a really long driveway :confused:.
Pete
/ Sprayer? #16
teg, how long is your driveway? I did the math, but it came out to a really long driveway :confused:. Pete
It's about a 3/4 mile long that I spray... I don't own it all. 6' x 2 (out & back) x 3960 (5280' x 0.75) = 47,520 ft2 (divided by 43560 ft2) 1.09 acres. Actually, this was more with the electric sprayer I had... with the pto pump, I do have some left over in the tank. I need to calibrate it better...
For the OP fence line, say you want to kill a 3 foot wide path?? by 3/4 mile, or 11880 ft2. About 0.27 acres. Since it's going to be over grown, he might want to use a sprayer that puts out ~25-30 gallons per acres, so he'll need at least 6.8-8.2 gallons.
Usually, people want to soak the brush and put out way more then is needed.
/ Sprayer? #17
charlz
I am sure it is covered by the 'it depends' clause ;) The pump on my 15 gal spot sprayer is pretty small. On the other hand my 30gal tow behind (which I picked up after burning up my small sprayer pump) has a much larger pump with better output capacity for boom spraying. Both are Shur-flo pumps.
/ Sprayer? #18
Tower 59:
Be very careful as here in Texas there are pretty heavily enforced laws about spraying. If you going to spray with anything but a very small sprayer you will need a license to do it. Wind drift and types of chemicals used are high on the sprayer police's list.
When you go to TSC or other places that supply concentrated spray you will be asked for your license if you want to buy more that a quart at a time.
Just thought you might like to know.:thumbsup:
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2011 John Deere 9770 (A64119)
2011 John Deere...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
HURRICANE (10) DRAWER (A64280)
HURRICANE (10)...
KUBOTA 48" PIN ON BUCKET (A64280)
KUBOTA 48" PIN ON...
