Spraying 2-4D
/ Spraying 2-4D #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I am spraying some lawn and old pasture getting ready to seed/overseed with grass. The 2-4D I purchased has suggestions on the amount of product to spray but does not have a suggested dilution. Any advice?
/ Spraying 2-4D #2
I mix at 1 1/2 or 2 ounces per gallon. BUT I have round up with it... I am sraying to kill all......
/ Spraying 2-4D #3
You need to know how much liqiud your nozzle or nozzles on your spayer puts out. Once you know that and your travel speed then you use the label dilution for the amount of spray. There are several thread here on TBN discussing the details. Be very careful of when and how you spray. Overspray and wind drift can cause problems. In south western OK this year several thousand acres of cotton was damaged by wind drift. The push is now on to make it a restricted use herbicide in OK like it already is in some other states.
/ Spraying 2-4D #4
My Extension Agent suggested always spray in the late afternoons to increase the kill of target species and lessen the kill of non-target species.
I am unsure of my dilution ratio.
/ Spraying 2-4D
Chuck, the problem is the label doesn't give me a dilution. I can adjust the tractor speed to give very different application rates of the dilution. I know I need to adjust the application rate of the dilution to give me the amount of actual product suggested. I was wondering if anyone had a suggestion of and optimal dilution then I could adjust tractor speed accordingly. If the wind doesn't die down later this afternoon I am not sure when I will be able to spray. The rest of the week is supposed to be rainy.
Are the guys doing aerial spraying the ones killing off the cotton crops or is there really that much drift when spraying from a 10ft boom behind a tractor?
/ Spraying 2-4D #6
Eric, you might want to check the label about how the 2,4-D will affect the germination of your grass seed. I know grass is not broadleaf but I think there is a warning about that.
/ Spraying 2-4D #7
Doesn't the active chemical in 2,4-D, Round-Up, etc. become nuetral or inactive within a few days of being applied? So it should effect grass seed planted more than a week or longer afterwards.
/ Spraying 2-4D #8
The booklet that came with the bottle will have a section with rates for spot spraying. It will vary depending on the plant, but usually either 1 or 2 oz per gallon.
/ Spraying 2-4D #10
2-4d will stay in the soil and go away after a while. There are possibilities that with too much application you can poison the soil with 2-4d.
Roundup is a foliage spray. It has to get on a leaf to do anything.
They are 2 totally different chemicals and work totaly different.
/ Spraying 2-4D #11
I have to talk myself through this every season.Lets make it simple.your spayer puts out say 10 gals per acre at lets say 5 mph. The label on the product will tell you how much to use per acre ,say one qt. as an example.so the dilution would be 1qt of product for each 10 gal. your sprayer holds. So you see the label cannot tell you the dilution because everyones spray equipment is different. The instructions are absurdley difficult to read. If you spray 20 gal per acre,you would mix 1qt of product per 20 gal water in the sprayer. I have to quit now before I confuse myself.
/ Spraying 2-4D #12
I use a product called ParIII which I think is largely 24D. The dilution ratios are posted by the manufacturer on the web. Not sure which product you have but dilution ratios, spray rates etc should be posted by the manufacturer on the web and like you said the label does not have any of that info. The place you bought it should have a brochure or data sheet that has the proper mix and application data:)
/ Spraying 2-4D #13
Oh ok, didn't know that. So 2,4-d kills from the root of the weed?
/ Spraying 2-4D #14
From Wikipedia:
2,4-D was developed during World War II by a British team at Rothamsted Experimental Station, under the leadership of Judah Hirsch Quastel, aiming to increase crop yields for a nation at war.[citation needed] When it was commercially released in 1946, it became the first successful selective herbicide and allowed for greatly enhanced weed control in wheat, maize (corn), rice, and similar cereal grass crop, because it only kills dicots, leaving behind monocots.
[edit] Mechanism of herbicide action
2,4-D is a synthetic auxin, which is a class of plant growth regulators. It is absorbed through the leaves and is translocated to the meristems of the plant. Uncontrolled, unsustainable growth ensues causing stem curl-over, leaf withering, and eventual plant death. 2,4-D is typically applied as an amine salt, but more potent ester versions exist as well.
Normally recommended 3 weeks before planting grass.
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
20800 (A56859)
20800 (A56859)
Gradall no crank no start (A61568)
Gradall no crank...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
Adams Tilt Trailer (A63118)
Adams Tilt Trailer...
