SSQA to Three Point Hitch Adapter
   / SSQA to Three Point Hitch Adapter #11
I've been wanting to build one of these so that I can use my landscape rake on the FEL to clear brush, leaves and large rocks from getting caught up or rolled into the gravel while I'm grading my 1/2 mile road.
I did the same thing, QH welded to a SSQA plate. Haven't painted mine yet. My only regret is welding it flat & not giving the QH some rollback.
I was able to get some rollback by grinding and positioning the QH. Picture shows it. More would be better but also a more complicated build.
******. Now I'm committed to building me one of these! Any pointers before I weld 'em together? Size thickness of the Titan plate?
The plate is 5/16. The bar across the top is 3/8. I got this style so can see through to the ball on my trailer mover for easy hookup.
One thing I thought about is gussets on the "wings" at the side. Decided not to. The QA lips top and bottom add a lot of stiffness. I don't think it will bend under intended use.
   / SSQA to Three Point Hitch Adapter #15
The 3 point adapter that I bought has a lot of extra rollback built in:
   / SSQA to Three Point Hitch Adapter #16
Xfaxman, that's a great setup you got there. No doubt it will fit just about any 3ph implements!!!
   / SSQA to Three Point Hitch Adapter #17
Thanks, it is cat2, so I have to use bushings for some things.
Xfaxman that looks great. Btw I used hook gussets following your suggestions in other threads.
   / SSQA to Three Point Hitch Adapter #19
Thanks. :thumbsup:
Using it to move box blade to workshop. Much better than lifting with chain.
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2016 CATERPILLAR 262D SKID STEER (A52709)
2016 CATERPILLAR...
2019 Freightliner Bucket Truck (A55973)
2019 Freightliner...
2015 SKY TRAK 6036 TELEHANDLER (A58018)
2015 SKY TRAK 6036...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
2019 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2019 FREIGHTLINER...
