Started my tower stand today
   / Started my tower stand today #151
Good point on the windows, thanks. I want to start one this winter or spring, so that is a great consideration. All I knew is I wanted the windows to open up not side way's. Did you use single panes or cheap doubles?
I have two double hung replacement windows, the other three windows is a slider with a stationary sash (don't like it but oh well) and two single hung windows from Mr. 2nds.
   / Started my tower stand today #153
Thanks Robert, I don't know if I will insulate mine since I am the only one that will use it. If the wife cares to go with me I may have to insulate it then it may make sense for me to use a few small double panes I have laying around. We don't get nearly as much cold as you guy's but it can get nippy at times.
   / Started my tower stand today #154
The windows in my blind are single pane glass. My walls are not insulate, just OSB on the inside and outside of the studs. I did put insualtion in the ceiling, but just two layers or R13 fiberglass bats that I had left over for insulating the walls of my house.
With the windows closed, I can heat my 8'x8' blind with my Coleman heater to comfy levels in just minutes on high. It's rated for indoor use, but just in case, I have a Carbon Monoxide alarm in there too. After it's good and warm in there, I can open the window and remain comfortble with the heater on low. I realize that having the window open defeats the purpose of the heater, but it's how I prefer it, and the heater does such a good job of heating the small space that it works out very nicely.
My windows cost around $30 each from Home Depot. When designing and thinking about my blind, the windows are what gave me the most trouble. I spent months trying to design something that I could make myself. I thought it would be too expensive to buy windows for it, and I thought that I could make my own for allot cheaper then I could buy them. I never bought or even looked at single pane windows before, but once I did, I realized that was the only way to go.
Eddie
   / Started my tower stand today #155
Great info Eddie, since your weather is very close to mine that will probably be the direction I go then. I have built several blinds for others, all transportable, but for myself I want to go permanent like you guy's have done partly for hunting, comfort and observation.
Your talking about the little gas heaters with the screw in bottles right?
   / Started my tower stand today #156
Yes, my heater uses the little bottles. Mr Heater makes them too, but when reading the reviews on Amazon, the Mr Heater models had allot of comments about how much noise they made. While I wasn't too concerned with the animals hearing it, I thought that it would annoy me to have to hear it. I have a clock in there now that drives me crazy with it's ticking. I'm going to toss it and get a digital one so I don't have to listen to that noise.
I went with the Coleman because it's a good name, and the reviews were all pretty good on it. There might have been another brand to choose from, but I forget what it was. I've used the Coleman several times now to take off the chill in the early hours, and can say that it works great. I have a supply of bottles on my shelf, but I'm still on my first bottle. Steph had it going next to her feet last week, and with two windows open, she was comfortable. I was at the other end of the blind, and also comfortable.
I remove the bottle from the heater when I'm not in there just in case there's a leak some day. I don't know if it will ever leak, or not, but it's not something that I take a chance with.
Eddie
   / Started my tower stand today #157
Eddie
Funny you mention that, I am the same way. If my neighbor had a dripping faucet it will almost wake me up and soon I will offer to fix it..:D constant little noises bother the heck out of me. A cricket in the woods no problem, but let one in the house and its WAR...
I have a couple Mr. Heaters and they do have a low hiss sound but it isn't anything I really pay much attention to. I only notice it when the heater goes out (fuel runs out). I don't know if the Coleman has the hose option but the Mr. Heater has a 12' hose option that allows you to connect the heater directly to a 20lb propane tank (which is a lot cheaper and nicer for a setup like a tower I think, no worry about changing tanks as one full tank will last a full hunting season.
I got the heaters cheap though and that is the main reason I bought them along with the fact they had the hose option.
   / Started my tower stand today #159
I was thinking that this evening while sitting in my ground blind. I have a 100lb bottle and a couple of 20lb'ers. I used the big one in my old shop to run the heater. I haven't used it except to get it tested, filled and then cooked a couple deer heads and an elk head. I also have a small bathroom type gas heater that would work, of course then I twould have to consider a vent for fresh air if i go "industrial"..:D
If you do go with the larger heater it wouldn't be a big deal to vent it. Since you are building the blind from scratch just factor in where you want the heater and run the vent.
42013 (A51691)
42013 (A51691)
BELSHE DT-235 (A53843)
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A52377)
2012 International...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
