Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,088
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
(I'm noticing my return key doesn't move this down so please pardon the difficult paragraph to read) The starter is on a backhoe/loader but frankly, that shouldn't matter. Pulled starter off, installed a new solenoid on it & put all back. Preface: If the battery is strong, the machine will start immediately and all is well. Since I also need a new alternator, I'm always working with a weak battery which brings this next problem. <p> If the battery is weak, the engine won't start right away. When I release the key, the starter will STILL keep trying to start. This gets the wires hot. I get around this by pulling the negative off the battery but the bottom line is, the solenoid won't release the "start machine" mode until it's 100% disconnected. Now, if the battery is strong and the machine starts up, the starter does NOT exhibit this problem. Only when the machine doesn't start. Any thoughts?
