Starter Solenoid
   / Starter Solenoid #1
Ford851
So. Bay Area, Ca.
Ford 851
Anyone know the Ford 851 4 post starter solenoid part number? What is the Napa equivalent part number? All I can find are the 8n or 9n part numbers. Are they the same as 800 series solenoids. Napa is closer and probably more reasonable. I know I've seen it posted somewhere, but my searches aren't turning up any good results.
This bring up the point, "how do you narrow a search"? Each time I put in a search line I get 2500 posts. Are searches done on the whole site or can you narrow them down to a single forum? What is the delimiter used for searches?
Best regards,
Ford851
   / Starter Solenoid #2
i don't know the part number but if sound guy or some of the vintage tractor experts see this they can help might send him pm good luck
   / Starter Solenoid #3
311007 is a ford 4 poster, 6v oe number
st541 is the napa #
   / Starter Solenoid #4
st541 is the napa #
   / Starter Solenoid
Thanks soundguy. If I am now running a 12 volt system shouldn't i be using a 12 volt solenoid to close the starter circuit? I think the two center posts are just a coil that when energized closes the contacts for the heavier battery/starter circuit. There must be some logic behind why a 6v solenoid is used. Bottom line: it works so use it:confused2:
Thanks,
Ford851
   / Starter Solenoid #6
they are a simply isolated base solenoid. the 2 small posts just conenct to the field coil.. energize them and the solenoid pulls in and connects the 2 larger contacts.
thus power from the key to one small post, and the safety starter button ( ground ) to the other small post.
the 6v solenoid works FINE on 12v.
if you want to get very particular about it, you can lookup the solenoid to a diesel 4 cyl ( 59-64 ), and it will have a 12v 4 post solenoid...
I've yet to ever change to a 12v solenoid.. :)
   / Starter Solenoid
Thanks sound guy,
Got it Really no need to change as you point out. Just curious. Too lazy to pull the specs.
Will be changing to 4 post when I install stuff to get back to original configuration.
See ya,
Ford851
   / Starter Solenoid #8
311006 is the oem #
ST542 napa echlin.. 12v
   / Starter Solenoid #10
Soundguy,
I have a 1958 Ford 861 D that's 12V and I need a solenoid. Checking NAPA there price for a ST542 is 31.00. Tractor Supply sells a 4 post solenoid for 12.99 but the part number is 311007FR for a 6V system. The specs on the solenoids appear to be the same, have you ever used a 6V solenoid from Tractor Supply for a 12V system?
   / Starter Solenoid #11
Just buy the $31 NAPA ST-542 and install the solenoid that will definitely work and be done with it.
John Deere 6120M (A57148)
John Deere 6120M...
2010 Honda CR-V SUV (A59231)
2010 Honda CR-V...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2021 XCMG CV123PDU ROLLER (A60429)
2021 XCMG CV123PDU...
