goeduck
Super Member
There would be no voids for air or moisture with the house wrap attached the the exterior walls The foam will stop all air movement, so the house wrap is more of a moisture barrier to protect the OSB from what might get behind the siding of the house.
This still was not making sense so I went to the DuPont website and this is what it said for homewrap and drainwrap:
DuPont Tyvek HomeWrap is the original house wrap, incorporating unique material science that helps keep air and water out, while letting water vapor escape
The unique material structure of Tyvek DrainWrap helps hold out bulk water, while allowing water vapor to pass through it, promoting drying in the wall system, which can help prevent mold and water damage
So they seem to be a weather barrier but not a true moisture barrier. Interesting. In any event, it sounds to me like a great combination to use spray foam plus wrap now that I understand it.
