Starting to Have a Few Issues With My M4800
   / Starting to Have a Few Issues With My M4800 #11
I had some sticky auto ignition switch issues recently, so I squirted some Fluid Film into the key slot, and worked it a bunch. Didn't fix it. At the same time, I needed to get a second key cut, and when the locksmith guy (it was a trick auto key, so I went to a locksmith...) came out to test it, I showed him the key problems with the original key. He came back with some WD 40. I kept my mouth shut. It worked like a charm, and has ever since. Go figure.
But, the ground and FF advice sounds good to me! Iffy vehicle electrics often are traced to poor grounds or corroded power contacts, and not the gauges themselves- especially when they're intermittent or, even better, more than one gauge.
Yes, the more than one gauge is extremely suspicious of either a very flakey key switch not putting full voltage to the gauge, or some corroded ground connection. I say lets fix the key switch one way or another first then start hunting down the gauge problem if it still persists.
   / Starting to Have a Few Issues With My M4800 #12
I had a squirrely problem like that once and despite my efforts to make a mountain out of a molehill, a wiser man that understands electronics told me it was likely a bad ground. I was so sure he was wrong we made a non dollar bet.
After thoroughly exhausting all the gauges and the alternator and wires and on an on and on and driving around with a battery in the car, it turned out to be a bad ground. Yet it still makes no sense. Yours sounds like a switch but my friend (who is an electrical issue troubleshooter) told me that almost all electrical issues are related to a bad ground. He says always start with the easiest answer and go from there on a problem.
   / Starting to Have a Few Issues With My M4800 #13
I've never used Fluid Film, but I have used WD40 in switches. At my property in NC, I've had dirt daubers fill up the key slot on a JD riding mower... and the exhaust pipe on a weed eater! Try figuring out what's wrong with your weed eater when that happens. Since then I keep a piece of blue tape over the key when it is parked and a waded up piece of paper in the exhaust.
   / Starting to Have a Few Issues With My M4800 #14
My 2004 M6800 fuel gauge does the exact same thing. Hopefully we can figure this out. Drives me nuts.
I'm glad we're all bouncing this around. We can all learn something and never get too old to do it. That's where I'm going to start is the ground. I've just got to get a few spare minutes, preferably in the day light hours, and go over it. I've learned this same thing about trailer lights. Check the ground first. I've also seen where my local Lowes carries Fluid Film so I know I can get some locally. I will be following up here as soon as I can get to it.
   / Starting to Have a Few Issues With My M4800 #16
Right approach. I'm not so sure about the Fluid film. It is a lubricant, akin to WD40, and I can't see it improving conduction between contacts. I'd sooner use the old TV repairman contact cleaner spray in there than any lubricant. Hope the grounding improvements work.
I managed to monkey with this between other commitments this weekend. I went ahead and shot the switch with the Fluid Film prior to looking for my grounding points. Put the key in and worked the switch as recommended. Seems all is still the same there. Questionable contact within the key switch, fuel gage still where it's been for a while and temp gauge bottomed out. Looked around and only see where the battery negative cable connects to the frame. Anyone have any idea where to look for any other grounding straps? I'd like to identify all of them and check them out. Thanks
Still needing to fix this issue. Used it weekend before this last and really needed the temp gauge to work (see pics- cattail fuzz is a pain). I called Kubota and priced the switch @ $36.59 & temp unit @ $26.36. Before I proceed I'm cleaning the one grounding point I can find at the battery and go from there. Still looking to see if any other grounding points are in play and only finding the one at the battery.
   / Starting to Have a Few Issues With My M4800 #19
At least on the smaller BX Kubotas there are grounding points near the starter and/or alternator to the frame. I have had to clean those before in order to get starter response. Should be more accessible on your larger machine without removal of side panels (?) I would also look around the fuse block up behind the instruments if you can get in there. Also, as a wild shot, have you tried jumpering another fully charged battery to it? Anything different? If it were any different you might have a low/undercharged battery but as i say that is a long shot.
   / Starting to Have a Few Issues With My M4800 #20
I've never saw so many cattails. Where is "Sold the 1/4 of a 1/4 but still tractorin' "???
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
