Staying cool in rural areas
   / Staying cool in rural areas #61
Tom_H,
Global Warming -> Yes.
Caused by Man -> No.
I have not tried the neck cooler. But on Friday I mowed the lawn which takes an hour. The temp was 96 so I would guess the heat index was over 100. I was fine mowing, I was wet with sweat and there was a breeze. A few places needed to be edge so I grabbed the hedge clippers and walk around the house cutting the grass here and there. Basically a slow walk. I was bent over so that the back of my head, neck and back was expose to the sun. After I got 3/4s the way around the house I had to stop and sit in the shade. The sun was about to kill me. I was out of breath, very tired, and getting dizzy. After sitting a bit I went and finished the last 30 feet or so. But even that few minutes heated me back up.
In the past I have taken a short towel, wetted it down and put it under a hat so that it covered my neck. I should have done this on Friday. :D I could see the next cooler working but a cheap towel will work just as well and cost less. :)
Later,
Dan
   / Staying cool in rural areas #62
Global warming...not in the Al Gore context, but yes in a natural cycle of weather.
I've used the neck coolers. They work somewhat but don't last long before needing re-filling. Setting on the dozer, pushing brush seems to be a good time to use one as opposed to when actively moving around working.
Its gotten to where it is just too much trouble to constantly re-fill them so I don't bother with mine anymore.
There is still no relief from the heat here in central Texas. With the porch Temperature at 101 I turned on the misters. That brought the temperature down to a comfortable 95 degrees.:D
My ponds are at record lows, and the grass, is hard to find, come on fall...:eek:
{"Something is wrong with that grass rig... Fire engines are red ;-)
RobertN in Shingle Springs Calif "}
RobertN I saw this fire truck at College Station last week and thought of you. It's not Red but it looks cool.
   / Staying cool in rural areas #64
Hmm... TxDon, your mister set up looks to be using PVC pipe and some kind of mister nozzles that I haven't seen elsewhere... want to elaborate?? I like the hammock!! Looks cool!
   / Staying cool in rural areas #65
What ya need is a Forest Fire! 40s in the morning and 65-75 during the day.
Of course you'll have to deal with the smoke and as far as my misters their dual purpose now.
Sure, I got the box with the 10 misters, 20 feet of PVC with female connections, drain valve and garden hose connection from Home Depot several years ago. They still have it but I don't know the cost.
   / Staying cool in rural areas #67
are you saying your electric bill is $750 per month??? sure looks like a good time to consider a geothermal system?
heehaw
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
HLA SE50AO600G LOT NUMBER 168 (A53084)
HLA SE50AO600G LOT...
Electric Concrete Mixer (A51573)
Electric Concrete...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
New/Unused AGT YSRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
