BrokeFarmerJohn
Veteran Member
- Joined
- Oct 7, 2016
- Messages
- 2,233
- Location
- Columbus Ohio
- Tractor
- 2017 Mahindra 5555, John Blue G-1000, Massey Ferguson 98, John Deere GP
But they are there if you need them and they would be convenient to use too. Pushing snow/ice on a parking lot that slopes is one good use for a steering brake. Give it a little right or left "rudder" and "tack into the wind". Working dirt up against a building is another good use for them. You can also use one to slow down a spinning wheel so the other wheel will take off and pull you out of a mud hole is. It can be used to "twist" you out of a stuck situation also and get your nose pointed downhill. It works as good or better than the differential lock, and you can use it while spinning a tire, you can also switch back and forth to "wiggle" out of a stuck situation, As well as just use one to make a sharper turn to miss an obstruction. Lots and lots of reason to use split brakes. Another arrow in your quiver. Try them some time and get good at using them, and you will like 'em too.![]()
It's people like you and rich is the reason I'm here. Lots of good info to read, I am not very experienced with tractors, I'm just now getting smooth and efficient with my FEL moving pallets and round bales while the tractor is moving.
My break pedal has always been locked together like it was just one pedal since I bought the tractor. But I do have the ability to split them if I need to. I read back to the beginning of this thread and got some good ideas to use them for and your post was like icing to the cake by the time I got to the end.
I'm sure I will find myself in many of these situations and I have the knowledge to use the split breaks for diff scenarios.
I have already caught myself kicking the tractor into 4wd going down a few small hills on the property with a round bale on the forks because I read a thread on here where a guy went down a hill with a load in 2wd, the rear end got light and he put the forks thew the siding of his building by the time he got stopped.
I'm sure actually using my split breaks will be next lol.
But I have only used the tractor on a reasonably flat property where the tractor is on grass (yard) or the concrete/gravel drive. So that's the main reason I haven't split the breaks. I have yet to use by deff lock either lol, so far 4wd has been more than enough.
When we got my dads old 53 case SC going again I used the split breaks on it a few times just fooling around and trying them out. I wanted to see how sharp it would turn. it's a 32hp 2wd tricycle tractor with 38in R1 on the rear.
Thanks guys for taking the time to share the knowledge
