gemini5362 said:
Roger I am not sure if the unit he is talking about is a heat pump unit or just an airconditioner with electric heating strips. I believe you can buy those. I do know that you can get a heat pump that goes into your window or wall. They have electric strips for emergency heat. Lowes sells them and I think on the box they tell you the amount of cubic feet that the unit will condition.
Roger, If you need much heat, don't rely on heat strips in an A/C unit. Heat strips are 100% efficient at converting electrical energy to heat but that doesn't make the heat cheap unless the electricity is cheap.
If the outside temp goes much below 40F for very long while you need heat then a heatpump isn't all that good either and if equipped will revert to pure electric heat via the strips, at greater cost till conditions allow it to go back into heatpump mode. At temps around 40F and above a heat pump will provide 3-4 times as much heat per kilowatt as electric strips or an electric heater. This 3-4 times figure makes it economical and reasonable in many instances to justify the extra cost of the heat pump since it will pay for itself out of energy savings in just a few years in many instances.
It is often more cost effective to spend more up front and get a higher SEER rated unit as the higher efficiency will reduce your electric bill and again this will more than pay for the extra up front cost within a few years.
The last time I did this it was an upgrade from AC with heater strips to a high SEER heat pump. Savings in electricity paid for both upgrades in less than 3 years and then it was just $ in the bank.
There have been significant improvements in available refrigerants and heatpump internal designs since the above example happened and going with a high SEER heatpump now is even a better deal than when I specked it for my moms house.
Readers Digest version: A high SEER heat pump will cost more to buy but will save so much in operating costs as to pay back the difference quickly and then just save you considerable money in reduced electrical charges.
An AC unit with heat strips (not a reversible heat pump) will cost more overall to buy and operate for a few years than the more expensive heat pump with internal back up heat strips even though initial cost will be less
A high SEER heat pump is a pay me now option. The cheap AC with heat strips is a pay me later but pay me lots more overall option.
You can't just calculate the cuft of the room and buy a heat pump to match. It isn't nearly that easy if you want to be assured of a good solution. Window U values, ceiling floor and wall R values, infiltration, insolation (sunlight, insOlation not insUlation), and such need to be considered. there are sites on the internet by the DOE to help you size your equipment, plug in the values and get the answer in BtU's
Pat
Pat
