PRF
- Joined
- Dec 21, 2012
- Messages
- 259
- Location
- Connecticut
- Tractor
- 2012 Kubota L5740, 1970 IH 2444, John Deere x485
Does anyone have - or considered installing - Fumoto valves? I have them on a couple of my vehicles and they make an oil change a nice, clean procedure. I have no idea if they make them the right size, tho.**edit: Appears they have them for at least some tractors. Allis Chalmers, John Deere, Kubota, and a couple others are listed on the Fumoto website.** Are the tractor drain plugs about the same size as automobile (cars & pickups) drain plugs?
Charlie
The lever is spring loaded it must be lifted up before you actually rotate it open. For added safety on agricultural use Fumoto recommends, You put a spring loaded hose clamp in the grove around the valve. This locks the lever in the down position and the clamp must then be removed before the valve can be opened. a ball valve has nothing to prevent rotation. You could always take the handle off a ball valve, but you would need an adapter for your threads making the whole assembly very long. I would worry about having a ball valve hanging out 2 inches and ripping the whole valve off. The fumoto valve does not protrude much father than the drain plug. Again i would not recommend the N models with a nipple to attach a hose.
We've used Fumota valves on our big trucks for milk hauling with no issues for many years. We have some long, dirt driveways and bumpy back roads to travel on, so we wrap a small zip tie around the slot where the lever is so it can't possibly rattle open.
Does anyone know off hand what size to get for an L5740? Planning on doing my 50 hr service this Fall..
