Stock battery is dragging after only 11 years
   / Stock battery is dragging after only 11 years #41
Lot of shipping problems on Amazon. Optima has dealers on their website, a local auto parts store stocked everything: yellow, red and blue.
   / Stock battery is dragging after only 11 years #42
Final follow up
The old Optima I put in the L48 to tide me over the winter went to the great recycling yard in the sky yesterday.
Bought in January of 2005, recycled in April of 2017.
Over the last 6 months I've had to replace the battery in everything I own except my 2500 HD which was replaced in 2013. 5 in total. 4 Optimas and 1 Autocraft for my wife's Chrysler 300.
   / Stock battery is dragging after only 11 years #44
The Cub mower was getting grumpy about starting. The battery in it (by PO) was a Tractor Supply 300CCA with a 2001 date code. So I assumed it needed replacing. To my surprise, it meters at 12.65vdc, every cell checks OK with the hydro, and it will still put out over 250 amps according to the load tester!
Not sure who manufactured TSC "Husky" batteries in 2001, but they did good by me!
   / Stock battery is dragging after only 11 years #45
Final follow up
Do you need a special battery charger for Optima batteries?
   / Stock battery is dragging after only 11 years #46
I may have you beat. I'm running a 2001 L3710 with the original factory battery. Every winter I expect it to die and it refuses to.
   / Stock battery is dragging after only 11 years #47
Yeah.....but the Optima costs a bunch, so you should buy one of those......not!
When yours finally does die, just buy one at Walmart, and keep a decent float charger on it.
Going that route, you may even get Optima life or better, and your wallet will remain a bit healthier.
   / Stock battery is dragging after only 11 years #48
November will make 10 years on my BX battery.
Last spring it needed a charge, so I thought this spring would be it.
it's been fine so far. I did notice it getting a bit weak as I kept on trying to start with a bad PTO switch.
This thread has made me optimistic for another couple of years.
   / Stock battery is dragging after only 11 years #49
My one bad experience with Optima battery that failed after 1 year (original purchase OEM battery) put me on the path of no more Optima batteries especially when I learned the replacement cost. My local distributor (NAPA) didn't even stock them because no one wanted to pay the price. I bought instead a NAPA 84 Legend battery for about half the cost of an Optima and it lasted 7 years. I bought the same battery for a replacement and if it goes 7years, I will have beat everyone's longevity test @14 years for the equivalent cost of one Optima.
The Legend was working perfectly until it shorted out internally. It went from 13.7 volts to 2 volts instantly and wouldn't take a charge. The NAPA dealer said that is generally what happens to older batteries, lead deposits slough off and settle in the bottom and eventually short out the cells.
   / Stock battery is dragging after only 11 years #50
Did someone say Optima batteries? Was watching the news the other day and this popped up. Seems two 18 wheelers got tangled up and one supposedly lost 15 pallets of batteries. There were other views of the mess, not all were Optima's. The reason it caught my eye was I had just replaced the battery on the JD X720 the day before with a Deka battery.
   / Stock battery is dragging after only 11 years #51
Deka must make good batteries... it's the OEM on my 2004 BX...
   / Stock battery is dragging after only 11 years #52
Wanna see what 'sulfation' looks like? Look at the white substance on the bottoms of these batteries, that's the lead powder forming on the bottom. When it gets bad enough, the battery will consume itself aka 'going negative'. When it gets bad enough, it's pronounced 'Thermal runoff' and you do NOT want to be around batteries when this happens! I'll share this picture of the sulfation, somewhere I have several pictures of the runoff situation, when I find them, I'll post one or two.
Sometimes...........disaster is the best teacher! :eek:
   / Stock battery is dragging after only 11 years #53
Batt Boom.JPGFound them! What a failed battery looks like, and another warning that you do NOT want to be there! Not likely to happen in an automotive type setting though, and that's a good thing. Gives you a good reason to exercise your batteries, doesn't it?
George
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
2001 Chevrolet Suburban SUV (A59231)
2001 Chevrolet...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A60432)
UNUSED RAYTREE...
2023 VIRNIG RBV50-72" HYD ROTARY BRUSH (A60429)
2023 VIRNIG...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2018 CATERPILLAR 335FLCR EXCAVATOR (A60429)
2018 CATERPILLAR...
