Stone Walls
/ Stone Walls #21
I laid this wall at a previous property. My wife saw this pile of rocks along the road and stopped to ask the owner if he wanted to sell them. He did, for all of 100 bucks! I rented a dump truck, took my tractor over and brought home eight loads of stone. I did have to buy a few more large flat stones for the steps.
/ Stone Walls #22
/ Stone Walls #23
I will sell you stones for $100 a truckload, you load, all day long! We're like the Saudi Arabia of stone here.
/ Stone Walls #24
Same here in NH - we are in glacial till and ledge and have trucked probably 200 yards of stone off of 4 acres. But did use a lot of them on the property.
/ Stone Walls
I laid this wall at a previous property. My wife saw this pile of rocks along the road and stopped to ask the owner if he wanted to sell them. He did, for all of 100 bucks! I rented a dump truck, took my tractor over and brought home eight loads of stone. I did have to buy a few more large flat stones for the steps.View attachment 3805046View attachment 3805047View attachment 3805049View attachment 3805054
Ok now we are starting see some really nice stone work.
How long did it take you to build these walls and stairs?
/ Stone Walls
/ Stone Walls #27
That is some very nice work as well, they will last a very long time!
Thank you, They need maintenance from time to time, as they move a bit over the winter
/ Stone Walls #28
Wow, some nice stonework! Mine pales by comparison, but I'm still kinda proud of it.
Main wall's about 4' high, continues to the right of the steps about half that height. Mostly hidden by some plants my wife put in on the embankment above.
/ Stone Walls #29
It takes a lot of work and some artistic talent to lay out a stone wall that stays in place. Around here the frost heaves in the winter are a bit damaging to them, but the trees and brush in the hedgerows are what does the most damage to them. There have been miles of them buried around here to open up little fields and make larger ones. That has been going on as long as I can recall.
When I was young I heard that many of the stone drain ditches and stone walls were built by the Irish immigrants to this country. I can remember the old timers when I was young talking about how the Irish worked for 15 cents a day digging ditches and filling them with rock for field drainage.
Edited; we have run across several stone drains in the fields here.
/ Stone Walls #30
OK, got out today and took some pictures. I literally have miles of walls, just wandered around and took a few shots.
This is what locally they'd call a "farmer wall," as in it was stacked by a farmer and not a stonemason. Around here property lines always have a stone wall, this wall is on a property line that was established in 1695. Note the largish stone to the left of the picture, it's over six feet long.
A lot of the older buildings have stone foundations, this barn was built around 1850. Since the ground is so stony it wasn't practical to dig a basement by hand, so the floor of the basement is at the original grade and fill -- mostly stones! was brought in to get access to the first floor.
This is the entrance to the basement of that barn. Some largish stones by the door.
This building is called a "pound," it was used for confining small animals.
/ Stone Walls #31
This is a wall I just don't get. It's not on a property line or any sort of boundary, it's a wall to nowhere. And it has the biggest stones.
Most of the time the biggest stones in a wall are on the ground and then ones that a man could lift are stacked above them. Kudos to the man who stacked this wall (for scale, that's a 4x4 post).
One final picture: Yesterday I talked about how fields that had been plowed would have very different walls. This is a shot of a wall around a field that was used to grow potatoes and turnips. It looks just like a heap of cobblestones. I'm sure there are some big ones at the bottom of the pile though!
/ Stone Walls #32
Yes, Lou there is an art in the part of looking at a rock and imagining where it fits in the wall, before picking it up! We have hundreds of feet of "farmer walls" of stacked rocks with tractor and thumb, then a few hundred feet of hand-stacked walls, and about 100' of what I call "fitted walls" no holes, flat and straight around the patio.
A good base of gravel and filler rocks are key to keep the wall together for the winter, and you are right - walls with trees and roots take a lot more maintenance as its always moving.
I really like seeing the different walls around the country and world, and here are some examples from Kentucky and the UK. They are similar in construction with flat rock and stacked tops.
/ Stone Walls #33
It was 100 bucks for all of the stone. It took eight trips to haul it home with a single axle 30k gross dump. This was about 20 years ago.
/ Stone Walls #36
I don't recall but it had to be more than a few days. I was driving truck but usually out and back in the same day. Not to mention keeping that 30 acre property up. My wife and a neighbor gal mostly took care of the daily barn chores. We had 25 horses give or take on site. (Not all on pasture)
/ Stone Walls #37
OK, I'll do $12.50 a truckload. No adjustment for inflation. When can you start?
LOL, that wall was a once and done project. Besides, it's a bit far to be hauling stones to KY. Not to mention, we have our own "share" of rocks here. There are beautiful walls ~3 feet tall topped with vertical stones similar to some of the photos already posted in this thread. Some of them run for miles.
/ Stone Walls
They have some impressive photo's on their site.
PT Wheel Driven Fertilizer Spreader (A64119)
PT Wheel Driven...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
WHITE 2-185 TRACTOR (A63291)
WHITE 2-185...
