OK. So my
L3400's fuel tank probably got some water in it from my fuel drum. I always use a water separating filter funnel and this is why I noticed it but I think the funnel filter has a leak in it and let some water through. The tractor has never done anything except start and run perfectly and has less than 500 hours on it. I keep the maintenance up and all. The following happened over about 3 days.
So I immediately drained the tank and the fuel filter bowl. (Well I did turn on the engine for less than a minute before draining the tank so I could move the tractor about 10 feet away to a spot I could work on it). Filled filter bowl up with clean diesel and bled via the banjo valve on injector pump. I went to mowing and noticed after a while that it was bogging down. RPMs dropping, losing power, running a little rough and making a little white smoke. So I bled again at the injectors. Seemed to help, but then I mowed for another hour and it happened again. Was running fine, but suddenly noticed that it was dragging again.
So I replaced the fuel filter and bled the lines. Seemed to run perfectly again and mowed for about an hour and it started bogging down and running rough again. So I drained the tank AGAIN and filled with fresh diesel. Problem still happened after 45 min to an hour of mowing.
So, when I bought the filter I noticed that there were supposed to be two o-rings, one big and one tiny. I didn't remember seeing the tiny one, so I bought one and put it in the little hole on the top of the filter element and reinstalled. Bled lines. Worked wonderfully and thought that fixed it.
I left it idling while I put the loader back on and unhooked and swept off the finish mower. I tried running the engine at full throttle and the problem surfaced again. Could not sustain more than about 2000 RPMs. Was making a little white smoke. Acted like it was starved for fuel. After idling a little bit longer the symptoms went away and it would sustain high RPM with no smoking or anything. Problem came and went in about 10 minutes.
Here is a 1 min video of it in its unhappy state:
It doesn't seem to be air in the lines. Those are thoroughly bled to the injector pump and at the injectors. There is likely no water at all in the fuel given that I have drained the tank TWICE. There are no fuel additives in the fuel. I never remember seeing the little o-ring though. It wasn't stuck to the housing and I don't remember it being on the filter element -- just the large one. I wonder if it got sucked up in the fuel line and into the IP or something. It just seems like it's not getting enough fuel to run at higher RPMs. Not sure this explains the little bit of white smoke though.
I don't really want to take it to a shop because they won't be able to reproduce it and will still charge me $400 or something.
I'm at a loss as to what's going on.
I figure I'll just keep an eye on it and see what happens.
Any ideas?
--- Lobanz
