Stupid little red tail lights
   / Stupid little red tail lights #11
I had work lights installed on my 7610, two 12V lights that I can swivel around with separate switches that only work when the lights are on. With one pointed back and the other front from the top of the ROPS I have great lighting for late night/early morning snow blowing, etc.
I thought about the strobe or revolving light too from the top of the ROPS but decided that it would be overkill.
   / Stupid little red tail lights #12
Daryl,
I have two cheap magnetic ones that plug into a power plug. One is from Wal-Mart and the other from AutoZone. They were both $19.98 each.
   / Stupid little red tail lights #13
I don't ever take my BX22 on roads so changing out the red lens for a clear one might be a good idea if I can find one? There have been times where just a bit of extra light in the back would have been handy but haven't really felt the need to add lights. Will have to measure them and do some searching.
   / Stupid little red tail lights #14
i think the laws state they must be on there. i use my flashers all the time i am on the road, my mail box is on the corner and the plows just bury it with snow, so i have to clean that mess up all the time. day or night i put the flasers on. now if u need light to work at night, get some rops mounted lights.
   / Stupid little red tail lights #15
Have you looked to see if your machine is pre-wired for a back light? My older 2150 already has the holes and wiring run to the underide of the right side fender ( sitting on the tractor). The wire is automatically hot when the headlights are on. Some of my friends put a switch in that hot line between the connector and the light so that it can be turned on and off right back there. Every tractor on my back road has a back light from TSC so they look "stock" - at least in my neighborhood.
   / Stupid little red tail lights #16
</font><font color="blue" class="small">( but even so people cant see a clear light and a bigs SMV sign and a big flashing yellow lights? )</font>
Do a little internet research into highway accidents involving tractors and or Slow Moving Vehicle's and you will have answered your own question. /forums/images/graemlins/smile.gif
   / Stupid little red tail lights #17
Has anyone connected to the prewired circuit on the right rear of the tractor for thier clear work lights? I am trying to use this circuit. It shows 12.0 volts but will not light my light. I tested the lamp and the switch is fine. This is on an L2500. Did bota wire in some sort of resistor on this circuit?
   / Stupid little red tail lights #18
I have used mine, are you sure you are getting a good ground on the light?
   / Stupid little red tail lights #19
Should be. The two wires I am using I tested with a meter first. The light also has a hot and a ground. So I thought I was all good.
Makinex Power Lifter (A52377)
Makinex Power...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
23311 (A51694)
23311 (A51694)
2014 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2014 Great Dane...
2005 National RV Inc. Dolphin LX RV (A53117)
2005 National RV...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
