I think that I may understand this one. The small transformer welders aren't recommended generally for tig by the welding companies producing them. They aren't typically as stable of an arc...possibly the voltage is geared a little high on the output as well. You can tig, but its likely it would be a hot and fast weld for sure. Low end amps aren't very good either.
Mark here is an old school trick for you. A lot of these little machines can't drop below 30 to 40-amps, this is where this trick helps. It won't help with arc stability tho. I've used a Tig rig on some pretty cheap machines, and never had a problem with arc stability, but maybe I wasn't paying any attention.:laughing:
I just copied and paste this, saves on typing.
Dropper resistor trick for CC constant current machines only!
To use that machine effectively then you need to use a dropper resistor made from a piece of 3/32" or 1/8" filler rod, depending on the amount of amps you want to drop.
Attach the 1/8" filler rod to the welding bench with a vise-grip and let it hang vertical then attach the ground clamp to the other end of the filler rod.
As the arc is established the filler rod (dropper resistor) will begin to heat thus lowering out-put amps at the torch.
CAUTION as the filler rod can become cherry red depending on the amount of amps being dropped.
To adjust for the correct amount of amps required of the weldment, one could trim the filler rod to different lengths or change the diameter although I've never found this to be necessary.
